It refers to inputs and outputs paths. Unless you add set_input_delay and set_output_delay then the tool wouldn't know about those paths. If you are designing an internal module (not final integration yet) then you can ignore these warnings until such time when you assign pins in the final stages in which case you need to know the external input/output devices timing parameters such as tCO,tSU,tH
