21613 Discussions
update QuartusII top-entity after modify the standard example
Hello,everyone.
I am new to QuartusII series software.
recently I follow the tutorial of ERIKA Enterprise about 2cpu design.
With a start of standard example in the installation directory,I complete the generation of SOPCBuilder part.
and I am confused about the following instruction in the tutorial:
go back to quartus ii, and update the symbol. connect back all the various pins
of the standard design, to their respective components.
the top entity of the project is a vhd file. From the context it seems like a bdf top entity.
How to update the symbol, since I changed the default component name and make some additions in the SOPCBuilder.
Thank you very much!!
After every generation SOPC Builder creates a file called your_sopc_file_name.vhd, search an entity with same name on it. There you will see the new signals and their names. So, in the top-level entity you can correct necessary parts in "portmap" code.
--- Quote Start ---
--- Quote End ---
Thank you for your reply!!
I found a file named my_project_name_sopc.v in the directory.
and compared with the original my_project_name.v, it seems like generated by sopc builder.
it is automatically assigned as a new top-entity of the project,right?
If I would like to create some connections between the interconnections,can I just create a partly bdf file of the project and make the connection?
I am quite new to this,looking forward to your reply.Thank you very much!!:)
--- Quote Start ---
--- Quote End ---
Usually, entity my_project_name_sopc defined in my_project_name_sopc.v, is instanced in the top-level entity (my_project_name.v). Pin assignments are made acording pin definitions on it.
What do you mean with
--- Quote Start ---
--- Quote End ---
--- Quote Start ---
--- Quote End ---
"Pin assignments are made acording pin definitions on it" ,so you mean I don't need to assign the pin artificially?
(By the way, I try to create a symbol block of the newly top-entity, and it remains 6% for a loooooooong time, seems like deadend.)
I mean if I would like to make some links inside the NIOSII soft core, excepting the outside pin. For example, I would like to link PIO with the reset_n of the second cpu to accomplish a multiprocessor system.
Looking forward to your reply. Thank you very much!!
--- Quote Start ---
--- Quote End ---
I said it because you're using "standard" example, and i guess it has pin assign ments acording to its top-level entity.
--- Quote Start ---
--- Quote End ---
I didn't understand your question.
--- Quote Start ---
--- Quote End ---
reset_n pin is always outside sopc system same as PIO pins.
