Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
usb transfer for ISP1362 on DE2 board
hi everyone:),
I'm trying to modify the firmware coding for DE2_NIOS_DEVICE_LEDI from DE2_demonstrations.
But I had problem to modify the coding to send more than 8 byte data per block.
I had modify the coding from ISR.c
void Isr_Ep01Done(void
...(got coding here)
Hal4D13_ReadEndpoint(EPINDEX4EP01,(data + offset), 16);
offset += 16;
c = Hal4D13_GetEndpointStatusWInteruptClear(EPINDEX4EP01);
Hal4D13_WriteEndpoint(EPINDEX4EP02, data, 16);
Hal4D13_GetEndpointStatusWInteruptClear(EPINDEX4EP02);
printf("\n");
void Isr_Ep02Done(void
unsignedchar bbuf[16];
int i = 0;
Hal4D13_ReadEndpoint(EPINDEX4EP02,&bbuf, 16);
if( sendCount < length)
Hal4D13_WriteEndpoint(EPINDEX4EP02, data + sendCount, 16);
sendCount += 16;
and also had modify the coding from MAINLOOP.c
void config_endpoint(void
/*port1 is OUT*/
Hal4D13_SetEndpointConfig(
D13REG_EPCNFG_FIFO_EN|D13REG_EPCNFG_NONISOSZ_16,EPINDEX4EP01
/*port2 is IN*/
D13REG_EPCNFG_FIFO_EN|D13REG_EPCNFG_IN_EN| D13REG_EPCNFG_NONISOSZ_16,EPINDEX4EP02
but still, i can't get it function correctly...
Can anyone help me??:confused:
I'm new in these, please help me...
THanks~~~~
summer
