Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
using h2f_axi_master
I used h2f_lw_axi_master to transfer data between hps to fpga. in this state maximum rate to on/off one IO pin was 3MHz. to increase rate, I used h2f_axi_master. in this state the rate increased to 6MHz, I think this rate of transforming data is very low. How can i use h2f_axi_master with maximum performance?
best regards
