21584 Discussions
vhdl addition result size
Hello, maybe a dummy question:
I am using arith package.
If I need to add 2 signed std_logic_vector of 3 bits,
The output should be a std_logic_vector of 4 bits,
3+3=6 ----->b"011" + b"010" = b"0110"
-3-3=-6 ----->b"101" + b"101" = b"1010"
A,B:std_logic_vector(2:0);
result:std_logic_vector(3:0);
but if I do this assignation
result<=A+B;
quartus said me "expression has 3 elements, but must have 4 elements"
Thank you.
result <= sign_extend(A) + sign_extend(B);
or
result <= (A(2) & A) + (B(2) & B);
Hello
I was doing the addition between two 22 bits std_logic_vector.
And I had to store the result in a 29 bits std_logic_vector,
So I was doing this
data_1_2005_29bits <=
(data_1_2005(21) & data_1_2005(21) & data_1_2005(21) &
data_1_2005(20 downto 0) );
I was repeating the sign 6 times, but with the function sign_extend my code will be more legible.
Thank you.
DABG
I have one more question,
the function "sign_extend" is also valid with the arith package?
I have this error after compiling:
Error (10482): VHDL error at sum_data.vhd(76): object "sign_extend" is used but not declared
Thank you
If you mean STD_LOGIC_ARITH library, it has a SXT() function, if I remember right. It's actually sufficient to extend one of two summands to the result size.
Hello FVM,
Yes, I mean std_logic_arith, sorry.
Well I extend 7 times the sign because the result will be the addition between multiples inputs.
result<=A+B+c+...;
Well, maybe I will begin with the package numeric_std, to see the advantages.
Thank you.
dabg
In numeric_std, you use the resize() function for the same result. This works for signed and unsigned types.
Yes, I meant resize() instead of sign_extend() in my first post. It works great and the code is still readable, typicaly you only need to extend one of the operands.
I had faced to this subtle of IEEE.numeric_std addition in VHDL.
So as to do the true addition (= addition with carry) I have to extend (resize) one operand, as you said to the desired size (max size + number of '+').
16 bits + 16 bits => 17 bits
16 bits + 16 bits + 16 bits=> 18 bits
result <= resize(s1_16bits + s2_16bits , 17); doesn't do what expected : the carry will be forgotten and result(17) always '0' (for unsgined)
7 years, this "bug" is present in my project.
Why IEEE did not pay attention to that ?
--- Quote Start ---
--- Quote End ---
Essentially a wrong expectation. The 16 bit numbers are added first, with 16 bit result size according to VHDL rules, unfortunately involving a possible overflow. Then sign extended after the overflow occurred. For the expected result, you need to sign extend first, then add.
result <= resize(s1_16bits , 17) + s2_16bits;
--- Quote Start ---
--- Quote End ---
Its not a bug, you just wrote the code wrong, as FvM explained.
The new fixed point libraries do width extension automatically.
