while trying to execute bit file in intel FPGA , the prints are displayed with some special characters in console terminal. What could be the issue?
Ideally, data_2 = 0x1024 should be printed in successive 14 times. But it is printing some special characters.
Thank you for contacting Intel community.
1- How do you execute the bit file?
2- Are you using Quartus?
3- Have you compile your design? Any error shown?
4- What is the device OPN?
Aiman
Thank you for responding.
1- After build of the software application project files, .elf file is created. Application project -> Run As -> NiosII Hardware.
2- yes
3- Yes I did compile. No errors are obtained in both design and software files.
4- Operation is to perform data integrity test. I am just writing same data at different offset and trying to read it back.
Thanks for the clarification.
I am checking this internally and will get back to you next week.
Aiman
Can you provide the .qsys and the C code application?
Aiman
We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
