Community
cancel
Showing results for
Search instead for
Did you mean:
BQi
what is the difference between same voltage and same temp?
the snapshot is timequest timing model
but we find the slow and fast model have same temp and same voltage.
so we want to know what is the difference between same voltage and same temp?
BQi
skyjuice
Timing Analyzer caters for all PVT effects (Process, Voltage and Temperature). In the highlighter corners, the voltage and temperature are the same, but it covers the process variance. Hope that helps.
BQi
What do you mean about process variance? Would u pls share us more detail about process variance?
skyjuice
Semiconductor chips are subject to variation during fabrication (https://en.wikipedia.org/wiki/Process_variation_(semiconductor)). That means when you purchase multiple units of the same device, some will be slow and some will be fast. To make sure all of them work normally functionally, users will need to ensure timing requirement is met in all timing corners.
