Rapid Storage Technology
Intel® RST, RAID
2177 Discussions
İntel Rapid Depolama Teknolojisi Kurulum Hatası
EMRAH
AlHill
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
EMRAH
https://www.mediafire.com/file/5c2l4dmlqljee2g/İntel.txt/file dosyayı sürükleyip gönderemedim mediafire linki oluşturdum ordan indirip bakarsınız
Andres_Intel
Hello EMRAH,
Thank you for posting on the Intel communities. I see that you are having installation issues with your Intel® Rapid Storage Technology (Intel® RST), I understand how frustrating this can be, I will be happy to help you.
Lütfen sizi sadece İngilizce olarak destekleyebileceğimi unutmayın. Bu yanıtı çevirmek için bir web çeviri aracı kullandım, bu nedenle bazı yanlış çeviriler olabilir.
To have a better understanding of the situation, please answer the following questions:
  • Contact the system manufacturer to get the proper driver.
    • To avoid potential installation incompatibilities, we recommend that you first check with your computer manufacturer and use the driver software provided.
    • Find links to computer manufacturer support websites (OEM - Original Equipment Manufacturer).
  • If there is no driver available from the computer manufacturer, you can try our generic Intel® Rapid Storage Technology (Intel® RST)
    • Keep in mind that this is a generic driver for general purposes. Computer manufacturers can change the features, incorporate customizations, or make other changes to the driver software or software packaging.
Andres P.
Andres_Intel
Hello EMRAH,
Were you able to download the drivers recommended previously?
Andres P.
EMRAH
@Andres_Intel Merhaba hayır indirme imkanım olmadı
DeividA_Intel
Hello EMRAH,
I was checking your thread and see that we have not heard back from you.
I’m going to close your post, but if you need further assistance, please do not hesitate to create a new thread.
Deivid A.
