Rapid Storage Technology
Intel® RST, RAID
2178 Discussions
Accidental unplug of SSD + RST = Permanent BSoD?
I had a bit of a misadventure today: while installing a new drive in my PC, I accidentally unplugged the SSD I use for RST and booted, which resulted in a BSoD... I tried the following things to solve the problem:
  • Replug the SSD ==> No luck
  • Run a windows repair ==> No luck
  • Disable acceleration via the CTRL+I menu ==> No luck
  • Set the HDD in AHCI mode ==> No luck
Is there a way to get around this BSoD or do I have to do a fresh windows install?
