Rapid Storage Technology
Intel® RST, RAID
2076 Discussions
Can I increase the size of my RAID 5 Intel RST with ASUS BIOS?
MAtwo
One of my RAID 5 disks failed. I had 3 x SSDSC2BW240H6 and I need to replace one... or all 3. This specific SSD has been discontinued and I am trying to find alternatives, and possibly upgrade at the same time. I wanna stay with Intel.
a- will I be able to up grade the RAID 5 1 disk at a time, let it build, replace the next... and have access to the higher speeds of the new SSD's as well as the added space?
b- Could you recommend SSD that will be compatible with my current Intel RST set up?
Operating System: Microsoft Windows 10 Home(10.0.16299 Build 16299)
Physical Memory (Installed): 16 GB
Processor: Intel(R) Core(TM) i7-5930K CPU @ 3.50GHz
System Type: x64-based PC
Total Installed Updates: 26 Updates - See Detailed View for more information
Display Adapter(s): DisplayLink USB Device 8.2.1952.0
NVIDIA GeForce GTX 970 23.21.13.8813
System Manufacturer: ASUSTeK COMPUTER INC.
System Model: X99-E WS/USB 3.1
Network Adapter(s): Intel(R) Ethernet Connection (2) I218-LM 12.15.22.6
Intel(R) I210 Gigabit Network Connection 12.15.22.6
Realtek RTL8811AU Wireless LAN 802.11ac USB 2.0 Network Adapter 1030.11.503.2016
Disk(s): Intel Raid 5 Volume 297.76 GB (available) 10.0.16299.371
Seagate Ultra Slim MT SCSI Disk Device 1.32 TB (available) 10.0.16299.371
WD Elements 10B8 USB Device 1.54 TB (available) 10.0.16299.371
WD Elements 10B8 USB Device 1.81 TB (available) 10.0.16299.371
WD My Passport 0748 USB Device 322.57 GB (available) 10.0.16299.371
Hello, melatwood. Thank you very much for taking the time to reach the Intel Communities Team.
Regarding your inquiry:
a) Indeed you can rebuild your RAID 5 one disk at the time with the Intel® Rapid Storage Technology. Once this is done you need to change the size of the partition on the Windows* Disk Management, please find the instructions to achieve so on the image attached to this post.
b) We do not recommend hardware. You can double check the compatibility of the hardware you would like to use with your mainboard manufacturer.
I hope this answers all your questions.
Antony S.
Antony S.
