Rapid Storage Technology
Intel® RST, RAID
2223 Discussions
Can't create a RAID-1 on MSI Card
JB14
Hi everybody.
I'm Jean-Louis from Belgium and I've a problem with Z270 cipset, BIOS and IRST Bios.
I sent hours & hours to try to create a RAID-1 with 2 * (250G SSD M.2) for installing WIN 10.
And this on the expensive MSI Z270-GAMING-M5
I found, yeseday, in Windows IRST utility the RAID-1 but completly crazy : never synchronized and unmanageable.
In Win disk management, the 2 "SSD disks" where completly different !!! and not declared as "mirrored".....
I think I found yesterday the lack between BIOS and the System : there is the declaration of the RAID that has to be done in IRST Bios via "CTRL I", see in the user guide.
I had access to this little Bios the first time I tried to create my RAID-1 but since that, it's impossible .....
Can someone help me to terminate this problem who drives me crazy because I send all my free time on this and I forget my family.
Many thanks.
Jean-Louis
Hello JLBO,
Thank you for contacting the Intel community.
I'm sorry the issue you have had trying to create a RAID 1.
I just want to understand better this problem, you have Windows® 10 installed and you want to create the RAID 1 using the Intel® Rapid Storage Technology or you are trying to create the RAID from the option ROM Ctrl+I to install the operating system?
Is the motherboard BIOS set to RAID mode?
Basically, When RAID is enabled in the BIOS; you see this RAID Option ROM command prompt during startup.
If you are trying to create the RAID to hardware level using Ctrl+I, you should be able to see the option to create RAID once you access the option ROM.
At this point, I will appreciate if you could attach some pictures with the issue you get to understand better the problem.
Ivan.
Hello ,
I'm following on this post to ask you if your issue has been resolved or if you need further assistance.
Ivan.
JB14
Hello friends.
I spent hours and hours without anay results and I decided to stop loosing my time.
On my first SSD M2, I install the system and on the second, the data. (just yesterday).
Believing to have finished, I click right for encrypting the datas (D:\) --> IMPOSSIBLE, bitlocker not present on click right !!!!!
Shit shit shit; I only had problems trying to buy "this professinal" machine for remote working since my home.
Thanks for your message.
Have a nice day.
Cheers from Belgium.
Jean-Louis.
I'm sorry that you could not create the RAID you wanted to, in case you need it, here is some information where it shows how to create a RAID:
http://www.intel.com/content/www/us/en/support/technologies/000005815.html Setting Up RAID When the Operating System is Already Installed
You can also check for more information here:
http://www.intel.com/content/www/us/en/support/technologies/000005789.html http://www.intel.com/content/www/us/en/support/technologies/000005789.html
If at some point, you still want to create the RAID, I strongly recommend contacting your motherboard manufacturer as well for them to guide you with some BIOS set up if it is needed.
Best wishes,
Ivan.
Hello ,
Ivan.
