Rapid Storage Technology
Intel® RST, RAID
2175 Discussions
Can't found RST CLI version for driver version 18.32.0.1006
pierrenichele
I use rstclipro.exe in my SCCM task sequence to manage Optane configuration on some devices.
For some Dell Inspiron 7706 2n1 (not all devices of that model), I can't find the correct version of RST CLI to enable Optane.
I've downloaded all version available on https://www.intel.com/content/www/us/en/download/19462/intel-rstcli-pro-for-intel-optane-memory.html
But when I execute "rstclipro.exe --OptaneMemory --enable", none of the versions works.
The only difference is for the last 2 versions who show error code 0x20000000.
After some test in BIOS, I've switched to AHCI then reswitched to RAID then this happened :
Version of driver switched from 18.32.0.1006 to 18.3.0.1003 and rstclipro.exe versions 17.xxx didn't work anymore. But problem still occur as I can't enable OptaneMemory.
Could someone provide a working version of RST CLI for version 18.32.0.1006 or 18.3.0.1003 ? Or maybe provide another solution ?
Pierre
Alberto_R_Intel
pierrenichele, Thank you for posting in the Intel® Communities Support.
In order for us to answer your questions and provide the most accurate assistance, we just wanted to confirm a few details about your system:
Is this a new computer?
When did you purchase it?
You mentioned "I can't find the correct version of RST CLI to enable Optane", so, that means that you have a physical Intel® Optane module installed on your computer and you want to know how to enable it, correct?
Is there any particular reason why you need RST CLI for those specific driver versions, 18.32.0.1006 or 18.3.0.1003?
Where did you get those drivers from, could you please provide a link?
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product=91600
Albert R.
Alberto_R_Intel
Hello pierrenichele, I just wanted to check if you saw the information posted previously and if you need further assistance on this matter?
Albert R.
Alberto_R_Intel
Hello pierrenichele, Since we have not heard back from you, we are closing the case, but if you have any additional questions, please post them on a new thread so we can further assist you with this matter.
Albert R.
