I have a PC based on Gigabyte GA Z77-DS3H motherboard and tried to install Intel RST driver.
This is from the IntelRST.log file:
2020:01:26 16:24:32:599: MUP OS bits: 0x492A8
2020:01:26 16:24:32:614: Scanning x64\iaAHCIC.inf (Name: AHCI64, Version: 12.8.20.1002)
2020:01:26 16:24:32:614: Section with the best match: INTEL.NTamd64.6.2
2020:01:26 16:24:32:614: Device: PCI\VEN_8086&DEV_3B29&CC_0106 (Intel(R) 5 Series 4 Port SATA AHCI Controller)
2020:01:26 16:24:32:614: Device: PCI\VEN_8086&DEV_3B2F&CC_0106 (Intel(R) 5 Series 6 Port SATA AHCI Controller)
2020:01:26 16:24:32:614: Device: PCI\VEN_8086&DEV_3B22&CC_0106 (Intel(R) 5 Series/3400 Series SATA AHCI Controller)
2020:01:26 16:24:32:614: Device: PCI\VEN_8086&DEV_1C02&CC_0106 (Intel(R) Desktop/Workstation/Server Express Chipset SATA AHCI Controller)
2020:01:26 16:24:32:614: Device: PCI\VEN_8086&DEV_1C03&CC_0106 (Intel(R) Mobile Express Chipset SATA AHCI Controller)
2020:01:26 16:24:32:614: Device: PCI\VEN_8086&DEV_1D02&CC_0106 (Intel(R) C600 Series Chipset SATA AHCI Controller)
2020:01:26 16:24:32:614: Device: PCI\VEN_8086&DEV_1E02&CC_0106 (Intel(R) 7 Series/C216 Chipset Family SATA AHCI Controller)
2020:01:26 16:24:32:614: Device: PCI\VEN_8086&DEV_1E03&CC_0106 (Intel(R) 7 Series Chipset Family SATA AHCI Controller)
2020:01:26 16:24:32:614: Device: PCI\VEN_8086&DEV_8C02&CC_0106 (Intel(R) 8 Series/C220 Chipset Family SATA AHCI Controller)
2020:01:26 16:24:32:614: Device: PCI\VEN_8086&DEV_8C03&CC_0106 (Intel(R) 8 Series Chipset Family SATA AHCI Controller)
2020:01:26 16:24:32:614: Device: PCI\VEN_8086&DEV_9C02&CC_0106 (Intel(R) 8 Series/C220 Chipset Family SATA AHCI Controller)
2020:01:26 16:24:32:614: Device: PCI\VEN_8086&DEV_9C03&CC_0106 (Intel(R) 8 Series Chipset Family SATA AHCI Controller)
2020:01:26 16:24:32:614: MUP OS bits: 0xB6D54
2020:01:26 16:24:32:614: Scanning x64\iaStorAC.inf (Name: RAID64, Version: 12.8.20.1002)
2020:01:26 16:24:32:614: Device: PCI\VEN_8086&DEV_2822&CC_0104 (Intel(R) Desktop/Workstation/Server Express Chipset SATA RAID Controller)
2020:01:26 16:24:32:614: Device: PCI\VEN_8086&DEV_282A&CC_0104 (Intel(R) Mobile Express Chipset SATA RAID Controller)
2020:01:26 16:24:32:614: E Win32 exception occurred!!
2020:01:26 16:24:32:614: Error code: 0x4E24 (20004)
2020:01:26 16:24:32:614: Error text: ''
2020:01:26 16:24:32:614: Extended error text: 'Error in device matching'
2020:01:26 16:24:32:614: Debug info: 'Setup.cpp (257)'
2020:01:26 16:24:32:630: Showing dialog: FINISH
Attached is the log file from the SSU utility.
What to do?
What version of the RST package are you attempting to use? I would suggest that you try version 14.8.16.1063, which can be downloaded from here: https://downloadcenter.intel.com/download/26759/Intel-Rapid-Storage-Technology-Intel-RST-User-Interface-and-Driver.
