Rapid Storage Technology
Intel® RST, RAID
2046 Discussions
Can't uninstall, can't reinstall
RMood
I got a message in the Samsung Magician application saying that I needed to update the Rapid Storage driver in order for the SSD to function properly. I downloaded the newest version from Intel and tried to install it, but it failed. The logs show it wasn't able to roll back either. I don't have rapid storage in my app list, so I can't uninstall it, and I can't seem to find it in the device manager even though Driver View shows it loaded. I tried installing the original version I had from the Asus downloads site, but that now fails to install as well. I'm at a loss, and I don't know what to do to get this resolved.
DISM.exe returned the following:
C:\WINDOWS\system32>DISM.exe /Online /Cleanup-image /Scanhealth
Deployment Image Servicing and Management tool
Version: 10.0.15063.0
Image Version: 10.0.15063.0
[==========================100.0%==========================] The component store is repairable.
The operation completed successfully.
C:\WINDOWS\system32>DISM.exe /Online /Cleanup-image /Restorehealth
[===========================98.4%========================= ]
Error: 0x800f081f
The source files could not be found.
Use the "Source" option to specify the location of the files that are required to restore the feature. For more information on specifying a source location, see http://go.microsoft.com/fwlink/?LinkId=243077.
The DISM log file can be found at C:\WINDOWS\Logs\DISM\dism.log
Hello pocketdrummer,
Could you please provide your operating system, computer model and chipset model? This will help to get the right version for your system.
Amy.
RMood
Windows 10 64-bit creator's update
Asus Sabertooth X99 motherboard
X99 Chipset
/thread/113558 pocketdrummer, thank you for that information.
Please try the following version; https://downloadcenter.intel.com/download/26700/Intel-Rapid-Storage-Technology-Intel-RST-?product=55005 Download Intel® Rapid Storage Technology (Intel® RST), before installing it use the method below to uninstall the current version installed.
Instructions to uninstall the Intel® RST;
  1. Open the Add/Remove Programs window
  2. Find the Intel® Rapid Storage Technology.
  3. Right click Intel® Rapid Storage Technology driver and select Uninstall.
  4. Follow the prompts stated by the Intel Installation Framework window to complete the process.
  5. Reboot the computer after the uninstall process has finished.
Please let me know how it goes.
Amy.
/thread/113558 pocketdrummer, hope you were able to follow the suggestion mentioned above.
Amy.
