Rapid Storage Technology
Intel® RST, RAID
Cannot Create RAID 5 Array
RTros
I have four 500GB SSDs that I want to combine using RAID 5, but the only options available in the RST interface are RAID 0, RAID 1, and Recovery. I've tried using several different driver versions, and I've tried using the BIOS configuration (both the UEFI version and the ROM version), all with the same options. From what I can tell, my system should be compatible with RAID 5, but the option isn't showing up. Any help would be appreciated. The RAID system report is below.
System Report
System Information
OS name: Microsoft Windows 10 Pro
OS version: 10.0.10586
System name: DESKTOP-3SJ2M2T
System manufacturer: Notebook
System model: P7xxDM(-G)
Processor: GenuineIntel Intel64 Family 6 Model 94 Stepping 3 4.001 GHz
BIOS: American Megatrends Inc., 1.05.10
PCH: 0xA145
Intel® Rapid Storage Technology enterprise Information
Kit installed: 15.8.1.1007
User interface version: 15.8.1.1007
Language: English (United States)
RAID option ROM version: 14.8.0.2377
Driver version: 15.8.1.1007
ISDI version: 15.8.1.1007
Storage System Information
RAID Configuration
Hardware Information
Controller name: Intel(R) Chipset SATA/PCIe RST Premium Controller
Type: SATA
Mode: RAID
Number of SATA ports: 5
Number of volumes: 0
Number of spares: 0
Number of available disks: 4
Rebuild on Hot Plug: Disabled
Manufacturer: Intel Corporation
Model number: 0x2822
Product revision: 49
Direct attached disk: S24CNXAH106226Y
Direct attached disk: S21HNXAGB23978T
Direct attached disk: S2RANXAH107873P
Direct attached disk: S414NB0JC23687A
Disk on Controller 0, Port 0
Status: Normal
Type: SATA SSD
Location type: Internal
Usage: Available
System disk: Yes
Disk data cache: Enabled
Command queuing: NCQ
Transfer rate: 6 Gb/s
Model: Samsung SSD 850 EVO M.2 500GB
Serial number: S24CNXAH106226Y
SCSI device ID: 0
Firmware: EMT21B6Q
Physical sector size: 512 Bytes
Logical sector size: 512 Bytes
Disk on Controller 0, Port 2
Status: Normal
Type: SATA SSD
Usage: Available
System disk: No
Model: Samsung SSD 850 EVO 500GB
Serial number: S21HNXAGB23978T
SCSI device ID: 0
Firmware: EMT02B6Q
Disk on Controller 0, Port 3
Status: Normal
Type: SATA SSD
Usage: Available
System disk: No
Serial number: S2RANXAH107873P
SCSI device ID: 0
Firmware: EMT02B6Q
Disk on Controller 0, Port 4
Status: Normal
Type: SATA SSD
Usage: Available
System disk: No
Model: Samsung SSD 860 EVO M.2 500GB
Serial number: S414NB0JC23687A
SCSI device ID: 0
Firmware: RVT21B6Q
Empty port
Port: 1
Port location: External
Hello RMT,
Thank you for joining this Intel Community.
I understand that you are having issues creating RAID 5. I would like to assist you.
I would like to get more information about your system, please run the Intel® System Support Utility and attach the report.
1.Download the Intel® System Support Utility and save the application to your system.
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product=91600
2.Open the application and click Scan to see system and device information. The Intel® System Support Utility defaults to the Summary View on the output screen following the scan. Click the menu where it says summary to change to Detailed View.
3.To save your scan, click Next and click Save. You can save the file to any accessible location on your computer.
Wanner G.
RTros
Thanks for the reply. The system support utility report is attached.
Hello RMT,
Thank you for your response.
According to ark.intel.com, Intel® 100 Series Chipsets support RAID 5. Please refer to the following link below.
https://ark.intel.com/compare/98085,98083,90584,90583
In this case, this is most likely a limitation issue. In other words, your system manufacturer did not enable this feature. My recommendation is that you can check whether this feature is available for your system first.
Wanner G.
Hello RMT,
Were you able to check with your system manufacturer if RAID 5 is supported by your system?
Wanner G.
RTros
After checking the information from my system's manufacturer, I discovered that the SATA ports are limited to RAID 0/1, and not RAID 5. I ended up settling for RAID 0.
