- Email to a Friend
I've had problems installing the Intel Rapid Storage Technology (10.1.0.1008) on DX58SO running Windows 7 Pro x64. All my attempts failed. An Intel tech rep suggested installing version 11.0.0.1032 for the DX58 (SO2/OG). That install was successful. However, I recently attempted to create RAID 5 volume using the software and the attempt failed due to an unknown error. The software suggested reinstalling the software as one solution. I will attempt to do that. But, I was wondering if Intel intends to update the DX58SO Intel RST driver from version 10 to version 11? What are the differences between Intel RST versions 10 and 11?
PS
I attempted to remove the RST 11 and install the RST 10. The system froze repeatedly on the windows start-up screen just as it did when I first installed the os. I was able to restore the os after several attempts using windows repair and system restore.
I downloaded and reinstalled the RST 11 to see if that would resolve my "unknown error" when attempting to create a RAID 5 volume. The reinstall did not resolve anything.
I think there is a problem with RST 10 for the DX58SO running Windows 7 Pro x64. I have not been able to install that driver on two DX58SO boards. The board's AA numbers ended in 501 and 705.
Is there a way to troubleshoot the RST and determine why this system fails to create a RAID volume? I attempted to create a raid volume from my "D" & "E" drives, but that attempt failed as well.
Message was edited by: Tim Golden
- Email to a Friend
My issue with Intel Rapid Storage Technology (RST), DX58SO and Windows 7 x64 is resolved with Intel RST version 12.5.0.1066. The link below was provided by Intel Tech Support on a Support Chat.
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=2101&DwnldID=22676&keyword=12.5&Downl... Download Center
After two Intel Support chat sessions where the techs were pushing CTRL I to create a RAID 5 volume in lieu of troubleshooting the RST, I was finally offered the above link, because I didn't want to reload Windows 7 and all the other programs on my system disk. If you use CTRL I to create a RAID volume, you will lose everything on the volume disks, to include the OS.
The DX58SO Support Driver Download Center has RST 10.1.0.1008. When I attempted to install this driver, my system froze at the windows start screen. I was required to repair windows and use system restore to get the system to boot again.
About a year ago, an Intel tech on Intel Support Chat recommended using the RST 11.0.0.1032 on the DX58SO2/DX58OG driver download to resolve the issue with RST 10 noted above. RST 11.0.0.1032 installed without freezing Windows, but would not create a RAID volume due to "unknown error."
Today, on Intel Support Chat, a tech offered a link to RST 11.2.0.1006 and suggested I remove all optical drives from the board. I did and I got the same results as RST 11.0.0.1032. The program loaded without freezing Windows, but fails to create a RAID volume due to "unknown error."
Today on my second Intel Support Chat, a tech offered a link to RST 12.5.0.1066, the link posted above. It worked. The program loaded without freezing Windows and it created a RAID 5 volume without errors.
I asked the techs why these versions of RST were not on the DX58SO driver download center and they both indicated that the driver download center is not up to date. I find that strange.
This RST issue has existed on three different versions of the DX58SO; boards with AA numbers that ended in 501, 503 and 705. So, I don't think this is an isolated tech issue.
If you're Intel RST program on a DX58SO running Win 7 Pro x62 fails to create a RAID volume due to "unknown error," then the fix is likely the link posted above.
- Email to a Friend
