I have a Dell Prec 5810 Win 10 Pro, all up to date with latest drivers from Dell.
It randomly gives a BSOD with the following error "DRIVER_IRQL NOT_LESS_OR_EQUAL iaStorB.sys
I see what appears to be updated drivers on this site for this. So far Dell basically doesn't really know what to do.
Has happened on two systems, random 4 are okay. It can occur just sitting at the desktop, with no apps loaded or any.
Does anyone have a solution for this - apparently we are not the only one having this issue, but Dell doesn't know which way to go. OS is clean, have reinstalled it fresh, doesn't matter, like I said it has occurred on two different machines.
Please advise, this is a rather expensive config and it can't be used for anything.
Thanks!
Stuart
Hello smillma,
Thank you for joining the Intel Communities.
Was there any software or hardware change before the issue started happening? Have you upgraded/added any hardware to your computer?
Do you have Intel® Rapid Storage Technology software currently installed in your computer? In case you have it installed, may I have the version of it?
In order to help you better I would like to gather more information about the configuration you have in the computer. Please attach to this thread the .txt file the Intel® System Support Utility will generate https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
To attach a file, you must click "Use Advanced Editor" on the upper right hand corner of the response box, then the "attach" option will appear on the bottom right hand corner of the response box.
Fred D.
Hello smillma,
I was wondering if you still need assistance regarding the blue screen of death you are having in your computer. In case you still need assistance just let me know.
Fred D.
Hello--
Same issue for me: Precision T5810 (Windows 7/64bit) has barfed up 4 BSODs in the last month. With the exception of swapping out the mechanical HDs for Samsung 860 Pro SSDs, the three year-old T5810 was in stock condition. The first Samsung SSD was swapped into the T5810 on Day One via cloning software to replace the boot volume. The system has generally been extremely fast and reliable.
The T5810 is used extensively for CAD operations, using AutoCAD, Meshmixer, Fusion360, Chief Architect, Adobe Suite software. Both Samsung 860 Pros were updated using Samsung Magician to ensure they were using the latest firmware. A 2TB RAID1 volume was swapped out for the 2nd Samsung SSD. Intel's Storage Manager is no longer used to manage a RAID.
The initial symptoms were noted in May: the Intel RSTe service began taking an unusually long time to initialize in the system tray after logging in to a Windows profile. Also, the elapsed time before the AV splash screen appeared grew longer, as if it was dependent on the same services that RSTe was using.
User notices that the mouse "gets stuck" or tracks slowly and unreliably before BSOD. In general, startup takes too long; RSTe take 90-120 seconds to load at startup; in CAD apps, the mouse tracks unreliably like the system is starved for resources.... but it's not. The system has 16GB RAM installed, idles at ~4GB in use.
New Windows profiles were created and tested (no change); Intel RSTe was updated from the Dell site (no change); Samsung RAPID Mode was disabled (no change); RSTe was uninstalled (no change); OS was reinstalled per Dell's instructions (no change); motherboard was swapped out under warranty per Dell's troubleshooting tree (no change). Dell's Precision Optimizer software was used to disable unneeded apps and inits (e.g., AutoCAD, Adobe, DropBox) to try to limit possible driver contention and maximize system resources, but there's no noticeable change in CAD or system performance:
I have four MEMORY.DMP files in hand. Each crashdump has been parsed with WinDbg(64), and each time the likely cause is identified as iabstor.sys.
Win10 upgrade is not yet an option as some installed software will require cost/effort to update to Win10 compliance; even so, it doesn't look like the Win10 version of iabstor.sys has a more recent stamp than the currently-installed version. I've downloaded Intel® System Studio 2018 in the hope of getting a more detailed symbol set for debugging purposes.
I made one more change today: I modified advanced system settings so that Windows no longer dynamically manages the pagefile: Both SSD have custom-sized pagefiles where min=max. This is an old performance trick from the days when RAM and mechanical drives were expensive and SSDs virtually didn't exist: contiguous pagefiles didn't fragment and bootup time was always faster.
I really don't think it's a hardware issue, but I'm running out of ideas and traps to set. All suggestions welcomed, and thanks in advance.
SteveG
Hello SBG_Consulting,
Thank you for posting in our Intel ® Community.
I understand that you are facing issues with the Intel® Rapid Storage Technology enterprise (Intel® RSTe) driver for your Precision Tower 5000 Series (5810).
In this case our support is in charge of the desktop version of this app, which is the Intel® Rapid Storage Technology (Intel® RST).
Based on the specs of your system we can see that it has a server chipset and a server CPU; which in this case needs to be supported by https://www.dell.com/support/home/hr/en/hrbsdt1 your manufacturer as this driver includes customized features added by Dell*.
Feel free to contact them in the link above for further assistance.
I hope this helps.
Diego Sanchez Campos.
Intel (R) Customer Support Technician
Under Contract to Intel (R) Corporation
Same problem here on two separate Dell 5810's, running on win 10. Completely up to date on a daily basis with drivers and updates. BSOD's happen periodically, no one thing causes. Have been happening for probably 8 mos, and we keep troubleshooting including rebuilding the PCs from scratch re: reinstall OS etc. Just came across this so thought I would add. This is very bad. Please help - send me email if you find a solution. P.S. Both 5810's also happen to be using Samsung SSDs.
this is very interesting. will try tomorrow and let you know! Thanks for the feedback!
Hey there. As per your post, I disconnected the dvd drive on 3/6 and I haven't had a single BSOD since then. Prior to that and with increasing frequency, I was getting one every other day. I've got a precision T5800 tower and I was getting the iaStorB.sys error when it BSOD'd. I guess only time will tell...?
Thank you for your help.
Rob
Also, which driver did you remove completely? Device manager/storage controllers/ the Intel(R) C660+/C220+ series chipset SATA RAID COntroller? AHCI COntroller? or the DVD/CD-ROM drives/HL-DT-ST DVD-ROM DTA0N driver?
Love you Smill12! Still haven't had the dreaded BSOD since disconnecting the dvd drive on 3/6/2019. Maybe someone should pass this on to the "Great and Powerfull" Dell? Haha! Maybe the info would actually get to the techs there? One can only hope.
I was able to stabilize the BSOD issue by modifying Windows memory parameters: try modifying virtual memory settings to have the following attributes
-- Don't allow Windows to manage memory automatically for you (uncheck that setting)
-- Manually set Virual Memory (pagefile.sys) so that the pagefile size is equal to the amount of memory you have physically installed (e.g. if you have 8GB RAM installed, set pagefile MIN=8192, MAX=8192). This will require a reboot.
-- Experiment with pagefile on a single SSD, rather than having the pagefiles on more than one SSD.
Optimization settings like these were common in earlier versions of Windows, and before SSDs became so affordable. They might be voodoo-- I'd like to hear your results.
My customer is still experiencing an unreliable cursor when she moves the mouse-- it either moves sluggishly, lags, or "jumps" after a delay. Very frustrating. It's disappointing that Intel says it's Dell's problem because Dell has customized iabstor.sys... And Dell's only solution appears to be Rope-A-Dope: offering to swap hardware components until the warranty expires (while the problem still persists).
In a previous position, I was in an IT organization that had a significant annual spend with Dell, and was spoiled by the access provided to engineers in Austin and Round Rock to cooperatively (and successfully) troubleshoot issues like this. It's gratifying when a BIOS, firmware, or driver update gets released to address an issue you've experienced, and it breeds customer loyalty like few things can.
I'm *still* hoping to find a dogged Precision or Intel engineer who's willing to investigate dump files, make suggestions, and either explain the iabstor.sys deficiency or tell how it's addressed by newer hardware and/or software drivers. Buying a new Precision might be an acceptable proposition if Dell or Intel could more conclusively explain why this 5810 (and yours) have become hopelessly unreliable.
this seems like it could be the problem also... will see if the DVD experiment works, if not, will try this... I do have 1 Samsung SSD currently system managed paging file size... I'll change to none if the BSOD comes back...
