I have a Dell Prec 5810 Win 10 Pro, all up to date with latest drivers from Dell.
It randomly gives a BSOD with the following error "DRIVER_IRQL NOT_LESS_OR_EQUAL iaStorB.sys
I see what appears to be updated drivers on this site for this. So far Dell basically doesn't really know what to do.
Has happened on two systems, random 4 are okay. It can occur just sitting at the desktop, with no apps loaded or any.
Does anyone have a solution for this - apparently we are not the only one having this issue, but Dell doesn't know which way to go. OS is clean, have reinstalled it fresh, doesn't matter, like I said it has occurred on two different machines.
Please advise, this is a rather expensive config and it can't be used for anything.
Thanks!
Stuart
- « Previous
- 1
- 2
- Next »
have the disconnect dvd drive implemented on one machine since last night. All good so far... I'll report back if any other issues and watch this trherad… Thanks a ton. lg
My test case will include an extra step. I won't lay hands on the system to physically unplug anything for a few more days. In the meantime, I logged in remotely and disabled the DVD drive in Device Manager. I've asked the customer to take note of any change of behavior on the 5810.
The next time I'm logged in, I'll check system logs to document the last BSOD. In the App log, I did that Chief Architect had barfed in late December. The system requirements for Meshmaker and CA dictated Precision as the platform of choice.
More soon.
I have two new Dell T7810s which have been crashing with the iaStorB.sys BSOD. Found this post. After trying several other fixes with no improvement, I removed the DVD drive through Device Manager then disconnected the data cable from the drive. With the DVD drive connected, Dell Quick diagnostics was crashing immediately; with DVD disconnected the Quick diagnostic tests complete. When looking at results, the DVD drive is the first thing tested. Methinks you are on to something here. No crashes the rest of the day. Will see how it goes!
The system with the DVD drive disconnected is behaving so far. The first time this system BSOD'd was right after a Windows update. The driver was uninstalled, allowed to reinstall at restart. BSOD came back at next Windows update. That's when I found this post and disconnected the DVD drive.
The other Precision which BSOD'd is powered off, haven't tested to see if problem is back or not. Too much else going on to deploy that system right now.
Interesting that it seems to only affect Precision systems running Windows 10. But not interesting enough for me to try to figure out why.
Checking back in..... my customer reports her T5810 has been "stable" since I disabled the optical drive in Device Manager-- I didn't physically disconnect any cables on the T5810.
Add my experience to the anecdotal evidence that disabling the DVD has improved the iabstor.sys bluescreen situation.
Just for reference, this thread helped us tremendously back in January.
We ended up going to devmgmt.msc (Device Management) and finding the DVD drive, right clicking, and selecting "Disable."
We did not need to disconnect any cables. Since then we've gone from 5 BSOD in 3 weeks to none in the last 6 months.
Thanks all posting your experiences with this.
Brady
I have a Dell Precision 5810 as well and the BSOD because of iaStorB.sys just started 2 weeks ago and this system has been in production for 2 years. There were no updates when it started.
It had it's first blue screen on July 4th when nobody was even using the machine. It would then blue screen every day at least once a day until I disabled the IRSTe service.
Dell's solution was to uninstall and reinstall IRSTe software and that worked for about a day. If that didn't work they said they would re-image the machine! I said no way! Let's find a solution to this. They didn't care.
I will have to try disconnecting the SATA cable from the DVD drive and report back.
There are over 4 Thousand views to this thread and Dell and Intel still have done nothing to fix the issue. Sad.
I have the same issue with lots of Bluescreen lockups on my Dell Precision Tower 5810. These Bluescreens are definitely increasing. All drivers and Bios up to date, even installed Intel's own version of Intel Rapidstore drivers from their website.
After reading the comments here, today, December 17 of 2019, I opted to disable the internal optical drive in the device manager.
Maybe this makes it unnecessary to physically disconnect the drive.
I would like to know if it is save to connect an external optical drive via USB or
if this once again introduces the problematic driver to the Windows 10 driven computer?
- « Previous
- 1
- 2
- Next »
