Hi Dell Team,
I encountered this problem for awhile now, and im afraid its harddrive failure. I tried with this possible method like this link https://www.intel.com/content/www/us/en/support/articles/000034272/memory-and-storage.html. but does not work when i scanned the drive.
[ Diag Events ]
DIAG 05/01/2021 10:20:09 Fail PSA 4304.14 Error 2000:0155. Validate Code : 118365 Hard Drive - Not installed
DIAG 05/01/2021 10:19:38 Fail PSA 4304.14 Error 2000:0155. Validate Code : 118365 Hard Drive - Not installed
DIAG 05/01/2021 10:12:56 Fail PSA 4304.14 Error 2000:0155. Validate Code : 118365 Hard Drive - Not installed
DIAG 05/01/2021 10:12:12 Fail PSA 4304.14 Error 2000:0155. Validate Code : 118365 Hard Drive - Not installed
DIAG 05/01/2021 07:37:45 Fail PSA 4304.14 Error 2000:0151. Validate Code : 66895 Hard Drive 0, incorrect status = 3E SMART Predictive Failure
DIAG 05/01/2021 07:36:03 Fail PSA 4304.14 Error 2000:0133. Validate Code : 82943 Battery - The battery cannot provide sufficient power
DIAG 05/01/2021 07:35:26 Fail PSA 4304.14 Error 2000:0151. Validate Code : 66895 Hard Drive 0, incorrect status = 3E SMART Predictive Failure
** Hard Drive 0-0-0 - DST Short Test **
Started: 05/01/2021 10:27:53
Ended: 05/01/2021 10:27:53, Elapsed time: 00:00:00
Test Results : Fail
Error Code : 2000-0151
Validation : 66895
Msg : Hard Drive 0 - incorrect status = 3E
Now, failure could happen next year or it could happen in a couple of hours. Bottom line, get your important data copied to another drive right away and be prepared to replace the drive almost immediately.
Hope this helps,
