Rapid Storage Technology
Intel® RST, RAID
2172 Discussions
Disk On controller 0, Port 2 Status: at risk (SMART EVENT) type SATA SSD
nsk55
Hi Dell Team,
I encountered this problem for awhile now, and im afraid its harddrive failure. I tried with this possible method like this link https://www.intel.com/content/www/us/en/support/articles/000034272/memory-and-storage.html. but does not work when i scanned the drive.
[ Diag Events ]
DIAG 05/01/2021 10:20:09 Fail PSA 4304.14 Error 2000:0155. Validate Code : 118365 Hard Drive - Not installed
DIAG 05/01/2021 10:19:38 Fail PSA 4304.14 Error 2000:0155. Validate Code : 118365 Hard Drive - Not installed
DIAG 05/01/2021 10:12:56 Fail PSA 4304.14 Error 2000:0155. Validate Code : 118365 Hard Drive - Not installed
DIAG 05/01/2021 10:12:12 Fail PSA 4304.14 Error 2000:0155. Validate Code : 118365 Hard Drive - Not installed
DIAG 05/01/2021 07:37:45 Fail PSA 4304.14 Error 2000:0151. Validate Code : 66895 Hard Drive 0, incorrect status = 3E SMART Predictive Failure
DIAG 05/01/2021 07:36:03 Fail PSA 4304.14 Error 2000:0133. Validate Code : 82943 Battery - The battery cannot provide sufficient power
DIAG 05/01/2021 07:35:26 Fail PSA 4304.14 Error 2000:0151. Validate Code : 66895 Hard Drive 0, incorrect status = 3E SMART Predictive Failure
** Hard Drive 0-0-0 - DST Short Test **
Started: 05/01/2021 10:27:53
Ended: 05/01/2021 10:27:53, Elapsed time: 00:00:00
Test Results : Fail
Error Code : 2000-0151
Validation : 66895
Msg : Hard Drive 0 -  incorrect status = 3E
n_scott_pearson
This is the drive, based upon statistics established by the industry and the manufacturer, predicting its imminent failure and you being warned of the fact so that you have time to transfer off your data before it fails completely.
Now, failure could happen next year or it could happen in a couple of hours. Bottom line, get your important data copied to another drive right away and be prepared to replace the drive almost immediately.
Hope this helps,
