Rapid Storage Technology
Intel® RST, RAID
2209 Discussions
F6flpy-x64-Non-VMD.zip and F6flpy-x64-VMD.zip Removed
PhilipYip
There seems to have been an update to the Intel Rapid Storage Technology User Interface and Driver Downloads Page:
https://www.intel.co.uk/content/www/uk/en/download/19512/intel-rapid-storage-technology-driver-installation-software-with-intel-optane-memory-10th-and-11th-gen-platforms.html
Now there is only the option to download the SetupRST.exe. Previously there was a F6flpy-x64-Non-VMD.zip and F6flpy-x64-VMD.zip. These are required to load the F6 drivers during the Windows Setup Screen and the zip format is particularly important when creating Windows Installation Media on another Operating System such as Ubuntu.
Labels (2)
Nerdtality
I will be following up with Intel directly and with other social media news outlets about this to see what is going on, people are going to visit sketchy websites to download these drivers now, such a dis-service to your own community. RST should have never existed if you where not going to support it correctly. Especially since this technology is still being produced. The Linux community is going to loose their minds!
BrijeshLadani
Those who Cant find VMD F6 driver
I extract RST.exe into zip
for that download attached file or follow  below link to download
https://drive.google.com/file/d/1lqCLrlqNV1Zrnkl1JjWvWIDMHCmd1S0z/view?usp=sharing
Cold_
BrijeshLadani
Yes unzip this and put unzipped directory inside the bootable usb or different usb
Then install the windows if error occurred for driver not found then go to browse button on that error screen then browse your usb and select "VMD" directory from unzip data
Pierre73460
Bonjour,
Par pitié aidez moi, ça fais 2 jours je cherche ce fichier et une fois que je l'ai enfin trouvé cela ne fonctionne pas.
Mon SSD n'est toujours pas détecté par l'installation de Windows.
Auriez vous une solution à me suggérer ?
Cdrlmt ,
Pierre.
osmanSKK
New User
Bonjour ,
J'ai le meme problème que toi , sa v eut pas detecter mon ssd la je suis bloquer a l'installation de windows , quand je met le pilote fourni dans cette discussion sa me met erreur lors de l'analyse des pilotes .
si quelqu'un peut m'aider
SetUp
Thanks A Lot! been battling with this for long , Across my experiences installing windows this surely gave me a headache, as i copied all the folders into the flash drive it automatically loads and boots with it without any error again, THANKS!!!!
TwinHealer
This was the ONLY Thing that worked for me!!!! Thank you @BrijeshLadani  for helping me to get a new ssd installed! I had completed the extractions but they weren't giving me the VMD F6 driver that I so desperately needed. Your tutorial and download link were the key to my success, so much so that I got an Intel account just to THANK YOU!!!!
DrAmjad
The same can be created using cmd or windows power shell. Its described in the README.txt topic 6.3
sudo64
Well i have finally found a driver that works, it might not work for all computers, but it worked for me, tell me if it works.
I'll also archive the driver in archive.org.
(You'll need 7zip to extract the driver.)
ral619
excelente me funciono esto en este modelo de equipo HP Laptop 15-dy2074nr
JAMESWT_MHT
Hello @PhilipYip
Reference Page
https://www.intel.com/content/www/us/en/download/779369/intel-rapid-storage-technology-driver-for-windows-10-iot-enterprise-and-windows-11-for-intel-nuc-13-pro-kits-nuc13l3.html?wapkw=nuc%20rst%20floppy
Direct link
https://downloadmirror.intel.com/779370/RST-F6-19.5.2.1049.4.zip
Or take last RST driver and with powershell extract it
https://www.intel.com/content/www/us/en/support/articles/000094664/technologies/intel-rapid-storage-technology-intel-rst.html
Open the terminal in the directory with SetupRST.exe by right-clicking the directory and selecting Open in Terminal or Open PowerShell here. If the options for CMD or Powershell* are not enabled, find each one to proceed with step 2:
For Powershell:
Open a PowerShell* window as an administrator
Navigate to the location of SetupRST.exe file >PS c:\windows\system32> cd “c:\users\Intel\downloads\
For CMD:
Open a cmd window as an administrator.
Navigate to the location of SetupRST.exe file > c:\windows\system32> cd c:\users\Intel\downloads\
Enter the following command: ./SetupRST.exe -extractdrivers SetupRST_extracted.
Hardwarespecialist
But this shouldn't be a thing.
On HP laptops with windows home. I am absolutely fricked without those drivers, no way to turn off vmd in the bios. no way.
I've even had an HP representative tell me that i shouldn't need to disable vmd.
All i can say is if you're buying a hp laptop and have to reload it. Good luck! I have even tried to load the drivers and sometimes they fail to load.
So thanks INTEL.
DonPk
J'ai bien tapé les commandes que vous avez donné mais on me renvoie ce message
'.' n'est pas reconnu en tant que commande externe, interne
Zebronics
Hello please
w1n73rf3ll
hello everyone
i have a Asus E1504G
with ufs storage there is no VMD settings or whatsoever .... i try all the drivers on this page and still my computer doesnt show the drive in the windows installation i need help to find the correct driver
details
Asus Vivobook go 15/14 model E1504G
processor core i3 N305
so i dont know where i can find the correct drivers!! need help
Shemnon
SetupRST
NONVMD and VMD Drivers
f6flpy-x64 and f6mdflpy-x64
From before they were pulled.
Getu-16
Hi Dears,
 This setup is not working for me; it says not compatible my pc dell Latitude 5430 how to resolve this please share your Idea.
