Rapid Storage Technology
Intel® RST, RAID
HDDの換装
Kmy
現在デスクトップPCでRapid Storage Technologyを使用しSATA HDD 2本でRAID1を構築しております。
SATA HDD2本をSATA SSD 2本に交換する予定なのですが
SATA SSDでRapid Storage Technologyを使用しRAID1を構築することは可能でしょうか。
VonM_Intel
Hi Kmy,
Thank you for posting in our Community.
Thank you for your inquiry regarding the transition from SATA HDDs to SATA SSDs in your existing RAID 1 configuration using Intel® Rapid Storage Technology (RST). To better assist with a seamless transition and ensure optimal compatibility and performance, could you kindly clarify the following details:
  • What is the motherboard model and chipset currently in use?
  • Is the system running in Legacy BIOS or UEFI mode?
  • Which version of the Intel RST driver is currently installed on your system?
  • Was the RAID initially created using the Option ROM (Ctrl + I menu), UEFI RAID setup, or via the Intel RST Windows utility?
  • Do you intend to retain existing RAID data during the transition, or will you be initializing a new RAID 1 volume from scratch?
  • Is your current system chassis adequately ventilated for SSD usage, especially during sustained high I/O?
Have a nice day!
Von M.
VonM_Intel
Hello Kmy,
Von M.
VonM_Intel
Hello Kmy,
I have not heard back from you, so I will close this inquiry now. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Von M.
