Rapid Storage Technology
Intel® RST, RAID
2213 Discussions
HELP!!! RAID 0 Drive has been removed
AAntr1
A few weeks back I installed the RST driver from my motherboard manufacturer. My motherboard is about 3-4 years old and the newest RST driver didn't seem to work with my system. I gotsni an error message from the RST stating that my "system detected one or more errors, and data may be lost," however the drive showed up OK and everything was accessible (I did try to understand the errors by checking the RST desktop application but it didn't provide any additional information, and didn't even list the RAID). A short time ago, I received a new message from the RST to the effect that my RAID 0 drive had errors and has been removed. I can no longer access the drive, nor does it even show up. Any ideas why I may have been experiencing errors and how I can recover my data or get my PC to recognize the drive again?
Hello arcadioantrez
Thank you for joining the community
Looking into the information provided and in order to assist you better with your request, I will need to check some information on your computer. Please follow the instructions below:
1. Open the Intel Rapid Storage Technology user interface (Start > Programs > Intel > Intel® Rapid Storage Technology).
2. Click the Help icon.
3. Click the System Report icon.
4. Click Save.
5. Open the report, copy all the information (Ctrl+C) and paste it here (Ctrl+V) so I can take a look.
Leonardo C.
AAntr1
Fantastic, THANK YOU!!!! See below...
System Report
System Information
OS name: Microsoft Windows 10 Pro
OS version: 10.0.16299 9200
System name: DESKTOP-UENGTS6
System manufacturer: System manufacturer
System model: System Product Name
Processor: GenuineIntel Intel64 Family 6 Model 42 Stepping 7 3.401 GHz
BIOS: American Megatrends Inc., 3802
Intel® Rapid Storage Technology enterprise Information
Kit installed: 12.8.0.1016
User interface version: 12.8.0.1016
Language: English (United States)
Driver version: 12.8.0.1016
ISDI version: 12.8.0.1016
Storage System Information
Controller name: Intel(R) Desktop/Workstation/Server Express Chipset SATA AHCI Controller
Type: SATA
Mode: AHCI
Number of SATA ports: 6
Number of volumes: 1
Volume: Data
Number of spares: 0
Number of available disks: 1
Rebuild on Hot Plug: Disabled
Manufacturer: 32902
Model number: 7170
Product revision: 5
Direct attached disk: 000000001247091DD419
Direct attached disk: WD-WCAZAE770154
Direct attached disk: WD-WCAZAE784850
Direct attached disk: WD-WCAZA5779162
Direct attached disk: WD-WCAZA6064546
Disk on Controller 0, Port 0
Status: Normal
Type: SATA SSD
Location type: Internal
System disk: Yes
Disk data cache: Enabled
Command queuing: NCQ
SATA transfer rate: 6 Gb/s
Model: M4-CT256M4SSD2
Serial number: 000000001247091DD419
SCSI device ID: 0
Firmware: 040H
Physical sector size: 512 Bytes
Logical sector size: 512 Bytes
Disk on Controller 0, Port 2
Status: Normal
Type: SATA disk
System disk: No
SATA transfer rate: 3 Gb/s
Model: WDC WD20EARX-008FB0
Serial number: WD-WCAZAE770154
SCSI device ID: 2
Firmware: 51.0AB51
Physical sector size: 4096 Bytes
Disk on Controller 0, Port 3
Status: Normal
Type: SATA disk
System disk: No
Serial number: WD-WCAZAE784850
SCSI device ID: 3
Firmware: 51.0AB51
Disk on Controller 0, Port 4
Status: Normal
Type: SATA disk
System disk: No
Model: WDC WD20EARS-00MVWB0
Serial number: WD-WCAZA5779162
SCSI device ID: 4
Firmware: 51.0AB51
Disk on Controller 0, Port 5
Status: Normal
Type: SATA disk
System disk: No
Serial number: WD-WCAZA6064546
SCSI device ID: 5
Firmware: 51.0AB51
ATAPI device on Controller 0, Port 1
SATA transfer rate: 1.5 Gb/s
Model: HL-DT-ST BD-RE WH10LS30
Serial number: K9ZA8AH3119
Firmware: 1.01
arcadioantrez: You are welcome. Thank you very much for providing that information. We will do further research on this matter, as soon as I get any updates I will post them on this thread.
Leonardo C.
arcadioantrez: I just received an update in this matter, based on the report you gave us, the SATA mode is set to AHCI, and for the Intel® RST and for a RAID configuration to work, it needs to be set to RAID.
Also, the version of Intel® RST that supports Windows® 10 does not support the chipset installed on your computer.
The best thing to do in this case will be to set the SATA mode to RAID, then re-install Windows® 8.1 or an older operating system and create the RAID from scratch.
Alberto R
