Rapid Storage Technology
Intel® RST, RAID
2213 Discussions
I would like to get back my 1 tb hdd
VPoud
hi I was new to this intel rapid technology thing I didn't knew how it work and I mess with it and now I am unable to access my 1 tb hdd
I hope you understand by the picturesScreenshot (6).pngScreenshot (5).pngScreenshot (4).pngScreenshot (3).pngScreenshot (2).pngScreenshot (1).png
AlHill
Did you take a backup before experimenting?
Doc
VPoud
no anyway I don't need any files.
n_scott_pearson
Your 1TB drive is currently being used as a recovery drive for your 120GB SSD. You need to go into the Manage tab and remove the coupling of the two drives - essentially remove the array. Whether your SSD's contents (i.e. your Windows install) will survive this process is unclear.
BTW, you can also kill this array from within the BIOS.
Hope this helps,
VPoud
n_scott_pearson
Then you didn't do it right. RTFM!
