Rapid Storage Technology
Intel® RST, RAID
2139 Discussions
Intel RST Raid 5 expansion Help
clarkcc
I am running Intel RST trying to expand raid and does not have an option in manage just able to add drive as spare.  i have read that you can with older versions, what am i missing?
System Information:
Operating system: Microsoft Windows 11 Pro 64-bit
OS version: 10.0.22631
OS language code: 1033
System manufacturer: Dell Inc.
System model: Precision 7780
Processor: 13th Gen Intel(R) Core(TM) i9-13950HX
BIOS: Dell Inc. 1.15.0
Intel® RST Information:
Driver Version: 19.5.1.1040
Hardware Information:
Link Power Management: No
Controller: Intel RST VMD Controller A77F \\Scsi0
Type: VMD
Supported number of disks under controller: 8
Supported number of volumes under controller: 4
Disks marked as spare: 0
Disks marked as available: 1
Automatic rebuild on hot plug: No
Vendor ID: 0x8086
Device ID: 0xA77F
Disk on: Controller 2, Port 0
Model: Samsung SSD 990 PRO 4TB
Status: Normal
Type: PCIe
Logical sector size: 512
Physical sector size: 512
System disk: No
Usage: Array disk
Serial number: 0025_3849_41A1_98F8.
Controller serial number: S7KGNU0X933345V
Firmware: 4B2QJXD7
HMB Supported: No
Disk on: Controller 3, Port 0
Model: PC SN820 NVMe WD 4096GB
Status: Normal
Type: PCIe
System disk: No
Usage: Array disk
Serial number: E823_8FA6_BF53_0001_001B_444A_48CB_C264.
Controller serial number: 232032446309
Firmware: 62012435
HMB Supported: No
Disk on: Controller 4, Port 0
Status: Normal
Type: PCIe
System disk: No
Usage: Available
Serial number: 0025_3849_41A0_18A8.
Controller serial number: S7KGNU0X900690A
Firmware: 4B2QJXD7
HMB Supported: No
Disk on: Controller 5, Port 0
Status: Normal
Type: PCIe
System disk: No
Usage: Array disk
Serial number: 0025_3849_41A1_98EA.
Controller serial number: S7KGNU0X933331N
Firmware: 4B2QJXD7
HMB Supported: No
Labels (2)
DeancR_Intel
Hi clarkcc,
Thank you for posting in the Community!
Please share more details about the issue so I can assist you effectively.
Did you do recent changes with the system?
Have you performed other troubleshooting steps?
Dean R.
DeancR_Intel
Hi clarkcc,
Dean R.
clarkcc
the changes that I did were too add 2 additional harddrives and convert to a raid 5 with the 3 HD that i had went seemlessly. I added a 4th HD thougtht i would be able to expand . just no option for that that i can see in the RST management.
I am not sure what specific information you are looking for, also do not know what trouble shooting steps to preform, I have found one pdf and it was from 2011 version 1 user guide for RST.
I f you have steps or suggestions to try please let me know
sorry for delayed response thought I signed up for notification when someone posted here
Thank you
Clark
DeancR_Intel
Hi clarkcc,
This is an acknowledgement message for your inquiry, do please wait as this will be investigated internally to be able to provide a resolution to your request. I will get back to you once I have the necessary information.
Dean R.
DeancR_Intel
Hi clarkcc,
Could you please follow the steps listed in this link and refer to page 22? Intel® Rapid Storage Technology (Intel® RST) Release with Intel® Optane™ Memory Installation and User Guide
Additionally, please download the Intel® Rapid Storage Technology Application from the Microsoft Store.
Intel® Rapid Storage Technology Application - Free download and install on Windows | Microsoft Store
For more details, you can also check out our Set Up a RAID-Ready System article.
If the issue persists, please let us know.
Dean R.
IP-Relay
I am experiencing the same problem as the original poster.  I have an existing RAID 5 configuration using 3x 10TB drives.  I have just installed a 20TB drive and want to expand the volume of the RAID configuration to include this Disk.  the Intel RST application only gives the option to add the drive as a spare.  How do I setup the drive as part of the existing RAID volume?
DeancR_Intel
Hi clarkcc,
Hi IP-Relay,
This is well acknowledged however, I suggest creating a new thread for this inquiry to avoid further confusions.
Dean R.
