Rapid Storage Technology
Intel® RST, RAID
2188 Discussions
Intel RST-Reset disk to non raid without losing data
DCoto
Hello all, newb here with a question. Someone at our facility set a 1TB WD Elements to be used as Raid 1 mirror with C:. Not only that but it is also being used to store data. It looks like half is for raid and the other half for storage. Is there a way to "break" the raid setup but still retain data that was stored separately? I appreciate any help!
Here is a snapshot from bios
Hello dcotos,
I understand that you would like to know if breaking the RAID would keep the data intact or not.
In order to best answer your question I will need to request the Intel ® RST system report, you can check in the link below how to create a system report:
https://www.intel.com/content/www/us/en/support/articles/000006351/technologies.html https://www.intel.com/content/www/us/en/support/articles/000006351/technologies.html
After it is reported, please post it here so we can have a look.
David V
DCoto
Here you go
System Report
System Information
OS name: Microsoft Windows 7 Professional
OS version: 6.1.7601 Service Pack 1 7601
System name: WORKSTATION
System manufacturer: LENOVO
System model: 7783C32
Processor: GenuineIntel Intel64 Family 6 Model 42 Stepping 7 3.3 GHz
BIOS: LENOVO, 9HKT46AUS
Intel® Rapid Storage Technology
Kit installed: 10.1.0.1008
User interface version: 10.1.0.1008
Language: English (United States)
Intel RAID controller: Intel(R) Desktop/Workstation/Server Express Chipset SATA RAID Controller
Number of SATA ports: 3
RAID option ROM version: 10.5.0.1034
Driver version: 10.1.0.1008
ISDI version: 10.1.0.1008
Device Information
Available space: 0 GB
Disk data cache: Enabled
Number of volumes: 1
Volume member: Volume0
Number of disks: 2
Array disk: W2ADF7W3
Array disk: W2AJMZZS
Status: Degraded
Type: RAID 1
Data strip size: 64 KB
Write-back cache: Disabled
System volume: Yes
Initialized: Yes
Verification errors found: 0
Blocks with media errors: 1
Physical sector size: 4096 Bytes
Logical sector size: 512 Bytes
Parent array: Array_0000
Number of disks: 2
Disk on port 0
Port location: Internal
Status: Normal
Usage: Array disk
Serial number: W2ADF7W3
Model: ST500DM002-1BD142
Firmware: KC65
System disk: No
Password protected: No
Native command queuing: Yes
SATA transfer rate: 6 Gb/s
Disk on port 3
Port location: External
Status: Failed
Usage: Array disk
Serial number: W2AJMZZS
Model: ST3500413AS
Firmware: JC66
System disk: No
SATA transfer rate: 3 Gb/s
Physical sector size: 512 Bytes
Disk on port 1
Status: Normal
Usage: Unknown
Serial number: KAZC5D15809
Model: HL-DT-STDVD-RAM GH70N
Firmware: NYA2
System disk: No
Disk data cache: Disabled
Native command queuing: No
SATA transfer rate: 1.5 Gb/s
Physical sector size: 0 Bytes
Logical sector size: 0 Bytes
Hello dcotos,
Thank you for your response,
We are currently reviewing the information, I apologize for the delay. I will be getting back to you as soon as possible.
David V
DCoto
Hello dcotos,
Upon review of the information and research, if you go ahead and select "Delete RAID volume" that option should break down the RAID without any data loss, also the same information should be on both disks since you are using RAID 1.
David V
Hello dcotos,
I am following up with your case and see that we have not heard back from you.
If you need more assistance do not hesitate to reply.
David V
