Rapid Storage Technology
Intel® RST, RAID
2209 Discussions
Intel® RST VMD Managed Controller 09AB - "Not OK" Status and Missing Drivers
AnitaNeupane
I am encountering an issue with the Intel® RST VMD Managed Controller 09AB on my Acer laptop running Windows 11. The device has reported a "Not OK" status. The device, Intel RST VMD Managed Controller 09AB, is reporting a bad status value. This device will not be available until the issue is resolved. The Plug and Play ID for this device is PCI\VEN_8086&DEV_09AB&SUBSYS_16161025&REV_00\3&11583659&0&30.
Device Manager Status: No drivers are installed for this device
I am unable to use the device due to this issue. I have checked Device Manager, but it indicates that no drivers are installed for this device. I have also tried basic troubleshooting steps such as restarting the system and checking for Windows updates, but the issue persists.
Could you please provide guidance on how to resolve this issue?
Ernesto_C_Intel1
Hi AnitaNeupane,
I would like to further understand the issue you've encountered:
1. May I know what is the Acer laptop model that you have?
2. When did the issue start? Do you remember doing any changes before the issue started?
3. What troubleshooting steps have you done before contacting us?
Ernesto C.
RandyT_Intel
Hi AnitaNeupane,
I wanted to follow up regarding the questions and information we shared with you recently. Have you had a chance to review them? Your feedback is invaluable in helping us determine the next best course of action.
Please let me know if you have any thoughts or if there's anything else you need from us.
Looking forward to your response!
Randy T.
RandyT_Intel
Hi AnitaNeupane,
Since I have not received any response from you, I will proceed with closing this ticket. Please note that this case will no longer be monitored.
If you have any new questions or inquiries, kindly submit another ticket, and we will be happy to assist you.
Randy T.
Charles_D
I am having the same problem with my Asus laptop (ROG Zephyrus M16 GU604VI). It started about three or four weeks ago and I don't know that I made any changes before noticing that I had a problem with my computer freezing for a second or two at various times (when an application started or changed, when notifications come in, etc.). I have talked to ASUS technical support and did a soft reset of the machine (take it back to factory but retain personal data on the machine), but the problem is persisting.
I have also run the system update to make sure that everything with Windows is updated. I have also run Asus' management software to verify that everything is fine/up to date from their end.
What other information might be helpful in drilling down on a possible solution for me? Appreciate the help!
-Charles
rarepidgeion
im also getting that same thing too it could be that you already have intel rst vmd manage controller a77f installed
