Rapid Storage Technology
Intel® RST, RAID
2242 Discussions
Intel RST installation - Error: 0x80300001
'm installing Win7 onto an SATA2 HDD configured for AHCI mode.
Intel's Rapid Storage Technology driver Read Me says:
If you are installing the operating system on a system
configured for RAID or AHCI mode, you must pre-install
the Intel(R) Rapid Storage Technology driver using the
F6 installation method described in section 5.3.
I am following the Read Me exactly and installing the driver during the operating system installation. After selecting the disk partition, I click "Load Driver", and insert a USB key with the drivers. It appears to complete the driver installation without problem, but when I try to continue the OS installation, I get an error saying: "Windows is unable to install to the selected location".
Some have suggested removing the USB key at this point, but it doesn't help. Neither does refreshing the partition view. I would appreciate any advice from someone who has had the same problem.
Allan_J_Intel1
If you are installation Windows 7 in AHCI mode, there is no need to install an additional driver for it, this is pre-loaded on the Windows installation disk, see below for more information:
http://www.intel.com/support/chipsets/imsm/sb/CS-022239.htm http://www.intel.com/support/chipsets/imsm/sb/CS-022239.htm
Allan
Thanks for your help. I will not attempt to pre-install the driver.
However, why does the readme.txt file that comes with the driver say this (below)? It seems there is a mistake in the readme file.
2. Create a floppy* containing the following files in the root
directory:
iaAHCIC.inf, iaAHCIC.cat,
iaStorAC.inf, iaStorAC.cat,
iaStorA.sys, iaStorF.sys and
TxtSetup.oem.
* Note: For Windows 7*, you can use a floppy, CD/DVD or USB.
3. For Microsoft Windows Win7*:
- During the operating system installation, after selecting the
location to install Win7, click Load Driver to
install a third party SCSI or RAID driver.
- Continue to step 4.
4. When prompted, insert the media (floppy, CD/DVD
or USB) you created in step 2 and press Enter.
5. At this point you should be presented with a selection
for one of the controllers listed in the Overview (Section 1)
of this document depending on your hardware version and
configuration.
6. Highlight the selection that is appropriate for the
hardware in your system and press Enter.
7. Press Enter again to continue. Leave the floppy disk in
the system until the next reboot as the software will
need to be copied from the floppy disk again when setup
is copying files.
