Rapid Storage Technology
Intel® RST, RAID
2200 Discussions
Intel Rapid Storage Technology Rebuilds Wrong RAID 1 Volume
MMast
Hi.
I am running Intel Rapid Storage Technology version 11.2.0.1006 under Windows 7 Pro x64.
I have the following defined:
Array_0000
RAID 1 Volume named System, degraded due to missing drive
1TB Drive (present)
1TB Drive (missing)
Array_0001
RAID 1 Volume named Media, degraded due to missing drive
2TB Drive (present)
2TB Drive (missing)
When I insert the missing 2TB drive IRST immediately assigns it to the volume named System in Array_0000 and begins rebuilding the volume. I wanted the drive to be assigned to the volume named Media in Array_0001, but I never am given a chance to do this.
How can I tell IRST to which volume a newly inserted drive is to be assigned?
Mike.
Kevin_M_Intel
Hello mbmast,
I understand the Intel® Rapid Storage Technology is automatically assigning the new drive to the RAID Array_0000 instead of the Array_0001.
This is an expected behavior since the software does not have the option yet to select what array do you want to fix. Since you have two arrays, the Intel® Rapid Storage Technology automatically will start rebuilding the first one.
Since you have RAID 1 configured in your system, the best and easiest option is to Access CTRL+I and set the Disks from array_0001 to non RAID. When you do this, the Option ROM will display a generic alert that says "All information will be lost"; however, this does not apply for RAID 1.
So by setting up the Disks from Array_0001 to non RAID disk, you will keep all the information in the HDD. Once done this, you may access the operating system and open the Intel® Rapid Storage Technology and from the Create tab you have the possibility to create a RAID from the selected disk and you also will have the chance to select the new disk and create the RAID Array from there.
You can get the Intel® Rapid Storage Technology user guide at the following link:
http://www.intel.com/support/chipsets/imsm/sb/CS-020670.htm http://www.intel.com/support/chipsets/imsm/sb/CS-020670.htm
