So I have everything set up to use ISR. It is in fact working on one of my HDDs right now. The dilemma is that I have a second HDD I want to do the same thing with but it looks like I can't set it up on two different HDDs.
Here is how I am set up:
Two 2TB HDDs
One 120GB SSD split into two separate 60GB partitions
One of the SSD partitions is set up to cache one of the HDDs. I want to use the other partition to cache the other HDD but see no option to set it up on another drive.
Anything I am missing in order to do this / any workarounds to allow this to work?
Thank you
The Intel® Rapid Storage does not see two partitions, it sees as one drive. If you like to cache both hard disk drives you need an extra SSD.
Allan.
