Rapid Storage Technology
Intel® RST, RAID
2189 Discussions
Intel Rapid Storage Technology
JThac
I had a failed drive in a raid 5 and replaced the drive., I went in and to told it to rebuild to new disk as described. It was going through the rebuild process. I have a feeling that it may not of completely finished as I walked off.
When I got back all the drives showed good including the new drive, but the status still showed degraded raid 5 in the overall RAID. I restarted server and it has been at the shutdown page for 4.5 hours. I do see some drive activity about every 5 seconds so I'm not sure if it is rebuilding in the background or should I just do a hard boot and see what the status may be..
Please respond, and thanks in advance for any help provided...
Jason
Hello jasonthackrey,
Thank you for joining this community.
In order for me to assist you better, please provide me with the .txt file that the System Support Utility will generate. To attach a file, you must click the "Attach" option on the bottom right-hand corner of the response box.
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
Diego S.
We just wanted to double check if you still need further assistance.
Please do not hesitate on contacting us back.
Diego S.
