Rapid Storage Technology
Intel® RST, RAID
M.2 PCIe as Cache
NAesc
Is it possible to use a M.2 PCIe as a cache drive for a RAID5 array ?
Hello Nathan3690,
Thank you for contacting Intel Communities.
In this case, only SSDs up to SATA III speeds are allowed for acceleration, you can use either SATA interface or M.2 form factor (as long as it is SATA III and not NVMe).
You can also refer to the following guide for more information:
http://www.intel.com/content/www/us/en/support/boards-and-kits/000005501.html Intel® Smart Response Technology User Guide
Hope this information helps.
Please don't hesitate in replying to this post if you need further assistance.
JC
Hello Nathan3690,
JC
NAesc
Thank you.
Is it compatible with the Z270 platform ?
I don't see it in the user guide :
System requirements
  • Intel® Z68, Z87, Q87, H87, Z77, Q77, or H77 Express Chipset-based desktop board
Hi Nathan3690,
You are welcome.
According to the specifications, the Intel® Z270 Chipset does support RAID 5, you can confirm the information https://ark.intel.com/products/98089/Intel-Z270-Chipset here, under I/O specifications.
It is also recommended to check the motherboard's specifications found on the manufacturer's website.
JC
