Rapid Storage Technology
Intel® RST, RAID
2055 Discussions
May Be Regarding Intel Rapid storage technology... Not sure
DPark14
Hi, I am Deepak Parkhi...
I am facing a specific problem and hence i am contacting you to help me resolve the issue. I am not a computer expert to an extent but know how to assemble PC,format, install the OS, softwares. etc.
I Have a Home PC built by myself with following configuration..
MotherBoard : Asus H61M-K
Processor : Intel i3-3220
RAM : Corsair Vengeance 1X8GB DDr3 1600 Mhz.
Harddisk : Kingston SSD V300 240GB or Segate 500 GB SATA Harddisk. ( This is not important )
Now let us start to the problem i am facing..
I will compare the issue or the problem with Windows 7 ( Home/ Pro / Ultimate ) VS Windows 10 Ver 1803 Build 17134.137 Latest. ( This is my current OS Liscenced copy )
See.. Let us assume that i have formatted my PC and installed a fresh Windows 7 Ultimate 64 Bit OS. I have also installed all the motherbaord Drivers Like, Graphics, Audio, Chipset, Intel Management interface, LAN etc and taken all the Updates of windows 7.
further Now.. I am using a stock market technical analysis software which is a Paid software and is for 1 PC. after installing the software i have to contact the software company to enable my subscription to my PC. Then they Copy the hardware ID of my PC to their system through remote access and enable the subscription for say 3 moths, 6 months, 1year. etc. This hardware id is nothing but few numbers and alphabets ( let me say this to start with ) . there is a provision in the software to access this hardware ID. Now let us assume that The ID is AQOP9047ITCX.
I am formatting my PC and again i does all the processes mentioned above and install the stock market software, The ID which is mentioned above will change.. Say MDOH035BAFC. ang again i have to contact the software company to change my ID and enable the sucscription to a new Hardware ID.
Previously i was using a laptop and i use to format my laptop quiet often, but that time, i was not facing this problem and this ID was used to remain the same.
after lot of thinking, i realised that, what am i doing different in laptop which i am not doing in my current desktop, by which this Hardware ID is not remaining the same.....
Finally i realised that i am not installing one driver which i was installing in my Laptop... This is the intel rapid storage technology driver.
further i searched the proper version of intel RST driver to my system and installed it..and found that everytime after NNNNNNNN numer of formats also the ID is not changing...Now comming to this Harware ID. I found that this ID is nothing but the serial number of my Harddisk or SSD. ( I have changed Hard disk to SSD and done all the process above. still i was getting the serial number of the respective Harddisk or SSD ) Hence it is not important, which storage media is used.
so for me this feature is very important as i donot have to contact the software peoples to change my ID after formatting. perhaps those peoples have also might be knowing that the Harddisk serial number will apper exactly after the RST driver is installed.
so... no problems...fine in case of windows 7....
further as with respect to time many peoples are switching to windows 10 and i as well, i got a liscenced copy of windows 10 and installed in my PC. probably, lots of updates is my concern for switching to windows 10 ( ever after convinience rollup in windows 7 )
after installing windows 10 and installing all the respective drivers for windows 10 including intel RST driver Ver 12.9.4.1000, the hardware ID is not shown as the serial number of the harddisk.
why...
if any one says your chipset is not supporting Intel RST... Then my question is why it is happening correctly in windows 7 and not happening in windows 10. Ver 1803.
( one thing i noticed that when i used to install RSTdriver in windows 7 after completion, it was telling me to restart.. after restaring again immediately message used to appear that restart to apply changes..This is not happening in windows 10. it was restarting only once.
Please help to understand the issue
Thanks a lot
Deepak Parkhi.
RAJU2529
New Contributor III
hey I checked the supported available drivers for the asus motherboard H61M-K , after checking ,I found that intel rapid storage technology driver is available only for windows 7 32 and 64 bit
moreover intel RST driver not available for windows 10 in asus official MB H61M-K website
https://www.asus.com/Motherboards/H61MK/HelpDesk_Download/ H61M-K Driver & Tools | Motherboards | ASUS Global
I don't know how you got windows 10 intel RST driver and you installed ?
moreover intel stopped releasing 6th series chipset drivers in the year2013 only, latest IRST is Version: 11.7.0.1013 (Latest) Date: 12/6/2012 from intel website for windows 8 and windows 7,
so I recommend you stick in windows 7 only, because no supported driver for asus H61M-K to windows 10
n_scott_pearson
That is correct. While the 3rd generation processor in use is fully supported on Windows 10, the board's 6 Series chipset is not (the 6 Series chipset is normally matched with 2nd generation processors, not 3rd). Since RST is a chipset feature, this means it is not supported.
Sorry,
DPark14
Thank You Very Much Mr Scott,
I understand.. Time now to upgrade my system.
Deepak Parkhi.
DPark14
Hi Scott,
Sorry to trouble you again..
As you said the i3-3220 in use is fully supported to windows 10, but the motherbaord H61 chipset not, i am getting intel original DH77EB Motherboard.. Will this support intel RST on windows 10. i am looking for the Hard drive serial number feature which i have described in my detailed report. I have searched on all websites, i didnot found any RST driver for windows 10. Though the H77 chiset specifications are saying that it supports Rapid storage technology, but the drivers are available only for windows 7 and 8, and not for windows 10.
Regard
Deepak
n_scott_pearson
Alas, there is a lot of confusion regarding support for RST on 7 Series boards...
First of all, because of the pending closure of the Desktop Boards business, Intel never completed the validation of Windows 10 support on their own 7 and 8 Series Desktop Board products and thus no drivers supporting Windows 10 were ever posted on the board download pages. Secondly, folks upgrading from Windows 7 and Windows 8.1 to Windows 10 found that, while there RAID volumes were supported initially, this support disappeared as they progressively upgraded Windows 10 itself (some reported issues at 1709, others at 1803).
If you go by the Release Notes, RST version 14.x is supposed to support 7 series chipsets on Windows 10. Folks have reported, however, that the INF file does not actually have entries to support this Series. Intel Customer Support responded to these reports by saying that the intent was to support 8 Series and later chipsets only, but never acknowledged that the Release Notes were actually wrong. Folks apparently got RST v13.x to install, but complained that this version was missing necessary bug fixes and enhancements for Windows 10.
Here is what I think you should do: progressively try these versions until one works:
https://downloadcenter.intel.com/download/26759/Intel-Rapid-Storage-Technology-Intel-RST-User-Interface-and-Driver Download Intel® Rapid Storage Technology (Intel® RST) User Interface and Driver v14.8.16.1063
https://downloadcenter.intel.com/download/25165/Intel-Rapid-Storage-Technology-Intel-RST-User-Interface-and-Driver Download Intel® Rapid Storage Technology (Intel® RST) User Interface and Driver v14.8.0.1042
https://downloadcenter.intel.com/download/25091/Intel-Rapid-Storage-Technology-Intel-RST-User-Interface-and-Driver Download Intel® Rapid Storage Technology (Intel® RST) User Interface and Driver v14.0.0.1143
https://downloadcenter.intel.com/download/24779/Intel-Rapid-Storage-Technology-Intel-RST-User-Interface-and-Driver Download Intel® Rapid Storage Technology (Intel® RST) User Interface and Driver v13.6.0.1002
If none of them work, well, I have no suggestions for what to do then...
DPark14
Scott,
You are simply Great!!!!
Deepak
