Rapid Storage Technology
Intel® RST, RAID
2055 Discussions
Need help with DX79T0 and sata option rom 3.5.0.1005
DShab
Good day. I have a motherboard DX79T0 and intel rapid storage technology enterprice - sata option rom 3.5.0.1005. There are new drives for 1TB and a 64MB cache.
When I do a raid - all right. Loading OS and can be placed on the raid anything.
After restarting the raid damaged. Error Occured ( 0) two drives of 4. One disc is recovered , the second is not. If you run Rebild - then still damaged after a reboot or during operation. On the other drives the same. How can I solve the problem and that the raid was working properly ?
Hans_B_Intel
Hi Lucerat,
Please send me more information about the build, like brand and model of the hard drives and the BIOS version that you have installed. But, it seems to me that if you are able to build the Raid but it fails upon reboot, we can consider maybe a bad hard drive.
DShab
Hi
Bios SIX7910J.86A.0650.2014.0307.0138
07.03.2014
HDD
WD1003FZEX-00MK2A0 х4 for Raid
Hitachi HUA722010CLA330 for OS and another
Instead, set 5 10. At the moment, three successful reboot , the disks are not damaged. So I switched slots Sata order. 2 connectors are separated using OS and just the hard drive. 4 adjacent - for Raid 10
In raid 5 100% damaged hdd after reboot.
Currently Raid 10 operates 3 days. But still scary that fails and will damage
For help i used documentation on motherboard
https://www-ssl.intel.com/content/www/us/en/desktops/desktop-board-dx79to-360view-demo-video.html https://www-ssl.intel.com/content/www/us/en/desktops/desktop-board-dx79to-360view-demo-video.html
4 plugs black and 2 blue
Previously, two drives were in Blue and 2 in Black. Maybe here and problems ?
Hans_B_Intel
Switching the Sata ports would not be a problem, I would consider this to be some power issue, have you tested with another power supply? What are the specs of you current power supply? Also, please let me know what is the board revision or AA number.
DShab
Hi, hansb_intel
I just first of all changed the power supply. Then motherboard put one block to another drive for testing. Power is not sags , only with connectors that regime change and helped raid . At the moment, without falling costs raid 10. May be raid 5 not supported or sata ports really need use only 4 black?
Motherboard name: DX79T0
Version: AAG28805-402
Serial: BTTO23400V1L
Hans_B_Intel
Hi Lucerat,
The Black and blue sata connectors use the same controller, the only difference would be in the transfer rate between the two colors (6.0 Gb/s Blue 3.0 Gb/s Black). This should not affect the raid array, at least not as far as the controller is concerned but you can always try and see if you Raid works better using only the 4 black ones.
DShab
Hi hansb_intel
Problem is over.
Seven days raid 10 work in black sata ports
Really blue and black ports not work together
I try tested, 10 raid is fail with black-blue ports.
10 raid not fail with use only black ports.
In future i want buy raid controller RS2BL080
Comments about intel rapid storage not trusted in core raid controller.
Thanks for your help!
Hans_B_Intel
Hi Lucerat,
DShab
Hi
07.03.2014
HDD
Hans_B_Intel
DShab
Hi, hansb_intel
Hans_B_Intel
Hi Lucerat,
DShab
Hi hansb_intel
Problem is over.
