Background: had working ASUS P5Q-E system with Raid5 set using 3 ~700GB drives. Decided to upgrade to 3TB drives. When I installed the first drive (as an extra) I discovered that intel matrix storage was out of date and would not support >2TB drive, so updated to 11.6.1030, along with chipset drivers.
Now 3TB drive worked ok, so copied entire original raid set to the single drive. Then removed original raid set of drives and installed other two 3TB drives, intending to "upgrade" from single drive to a new raid 5 set.
However, the iRST screen does not show any option to create an array.
Only one disk has been partitioned and formatted (it is NOT full, about 2GB left). The other two are uncommited. The system disk is the SSD.
Win7x64, P45/ICH10R chipset
Here is the system report if that helps...
System Report
System Information
OS name: Microsoft Windows 7 Professional
OS version: 6.1.7601 Service Pack 1 7601
System name: DADQ
System manufacturer: System manufacturer
System model: P5Q-E
Processor: GenuineIntel Intel64 Family 6 Model 23 Stepping 7 2.499 GHz
BIOS: American Megatrends Inc., 2101
Intel® Rapid Storage Technology enterprise Information
Kit installed: 11.6.0.1030
User interface version: 11.6.0.1030
Language: English (United States)
RAID option ROM version: 8.0.0.1038
Driver version: 11.6.0.1030
ISDI version: 11.6.0.1030
Storage System Information
RAID Configuration
Hardware Information
Controller name: Intel(R) Desktop/Workstation/Server Express Chipset SATA RAID Controller
Type: SATA
Mode: RAID
Number of SATA ports: 6
Number of volumes: 0
Number of spares: 0
Number of available disks: 4
Rebuild on Hot Plug: Disabled
Manufacturer: 32902
Model number: 10274
Product revision: 0
Direct attached disk: Z1F13K03
Direct attached disk: Z1F14NM6
Direct attached disk: Z1F14ZRH
Direct attached disk: f09070002
Disk on Controller 0, Port 0
Status: Normal
Type: SATA disk
Location type: Internal
Usage: Available
System disk: No
Disk data cache: Enabled
Command queuing: NCQ
SATA transfer rate: 3 Gb/s
Model: ST3000DM001-1CH166
Serial number: Z1F13K03
SCSI device ID: 0
Firmware: CC43
Physical sector size: 4096 Bytes
Logical sector size: 512 Bytes
Disk on Controller 0, Port 1
Status: Normal
Type: SATA disk
Usage: Available
System disk: No
Serial number: Z1F14NM6
SCSI device ID: 1
Firmware: CC43
Disk on Controller 0, Port 2
Status: Normal
Type: SATA disk
Usage: Available
System disk: No
Serial number: Z1F14ZRH
SCSI device ID: 2
Firmware: CC43
Disk on Controller 0, Port 5
Status: Normal
Type: SATA SSD
Usage: Available
System disk: Yes
Model: OCZ-AGILITY2
Serial number: f09070002
SCSI device ID: 5
Firmware: 1.33
Physical sector size: 512 Bytes
Empty port
Port: 3
Port location: Internal
Empty port
Port: 4
Any thoughts on how to procede?
- Tags:
- Storage
Hi!
I see that the Option ROM of the motherboard is still version 8.0.0.1038 so; I recommend updating the BIOS of the computer. BIOS updates will come with updates for the Option ROM as well which may help to fix this issue.
Since the operating system is installed on the SSD then you can try creating the RAID volume from the RAID BIOS. You can access the RAID BIOS by pressing Ctrl+I during POST. If you create the RAID 5 from the RAID BIOS using just the mechanical hard drives then the information that is on the SSD will not be deleted.
The bug is still present in 14.8.0.1042. No create button in RST interface. When will you fix it? Paul does not need a bios upgrade, Intel raid is a software raid, the bug is in drivers or in RST GUI. Please forward this bug report to the actual driver developer.
