Rapid Storage Technology
Intel® RST, RAID
2172 Discussions
No RAID option in Intel's RST - Dell Latitude E6440
BHelt
Core i-7 4810MQ, 16Gb 1333Mhz, 4600HD
I wanted to set up a normal RAID 0 array with 2 identical SSDs, however RST only gives me the option the create a recovery volume. I did update the driver and I enabled the RAID On option in the BIOS. I don't really know why it's not working.
I'd really appreciate it, if you could help me.
Benjamin
Silvia_L_Intel1
Hello Benjamin, Dell system comes with Recovery enabled by default. It will be necessary to access the BIOS or RAID Bios (Ctrl+I) in order disable that feature.
I suggest you contacting Dell so they can provide you the appropriate procedure.
