Rapid Storage Technology
Intel® RST, RAID
Over 4TB NVMe Drive support?
Ethan_Hsiao
Dear Sir,
I have a 4TB NVMe drive and config it with RST controlled.
But Windows always hang during OS boot.
I got the BSOD which shows "kernel security check failure".
Platform:
ASUS Z370-A w/latest BIOS 2401
UEFI IRST driver: 17.5.0.4136
OS: Windows 10 19H1 (1903)
Can somebody help me?
Thanks!
Ethan_Hsiao
Note:
If I disable RST and use the Windows in-box NVMe driver.
It can work fine.
Alberto_R_Intel
Ethan_Hsiao, Thank you for posting in the Intel® Communities Support.
In order fur us to provide the most accurate assistance for this scenario, we will do further research on this matter, as soon as I get any updates I will post all the details in this thread.
Alberto R.
A Contingent Worker at Intel
Alberto_R_Intel
Ethan_Hsiao, I just received an update on this matter.
Is the following the Intel® RST version that is currently installed in your system? If not please install version 17.7.0.1006:
https://downloadcenter.intel.com/download/29094/Intel-Rapid-Storage-Technology-Intel-RST-User-Interface-and-Driver?product=55005
There are some details about the RAID configuration that we would like to check, once you installed the Intel® RST version provided above, please gather the RAID report:
https://www.intel.com/content/www/us/en/support/articles/000006351/technologies.html
To attach the report, once you choose "reply" select the "clip" icon on the lower-left corner.
Alberto R.
Ethan_Hsiao
I've tried the latest driver version 17.7.0.1006 and still gotten the same BSOD result.
Ethan Hsiao
Alberto_R_Intel
Ethan_Hsiao, Thank you very much for letting us know those results.
We are sorry to hear that the problem remains after installing Intel® RST version 17.7.0.1006.
Please provide the RAID report so we can verify further details about the RAID configuration:
Alberto R.
Ethan_Hsiao
Hi Alberto,
The SystemReport.txt is attached.
The NVMe was not controlled by RST now due to it causes my system BSOD as my report.
Ethan Hsiao
Alberto_R_Intel
Hi Ethan_Hsiao, Thank you very much for providing the report.
We will continue with our research on this matter, as soon as I get any more details I will post them on this thread.
Alberto R.
Alberto_R_Intel
Ethan_Hsiao, There is another update on this matter.
Based on the fact, as you mentioned, that the problem does not happen when disabling the Intel® RST application and using the Windows* Inbox NVMe driver, it indicates that there might be a Windows* conflict or corruption.
Just to confirm, every time that you disabled/enabled the Intel® RST application, are you doing a clean installation of Windows*?
Please make sure to install version 17.7:
Alberto R.
Ethan_Hsiao
Hi Alberto,
Of course, I've installed a clean Windows a lot of times.
I gotten BSOD results after enable RST everytime.
About the installed version:
Please refer to my previous attachment (SystemReport.txt)
Intel® Rapid Storage Technology enterprise Information
Kit installed: 17.7.0.1006
User interface version: 17.7.0.1006
Language: English (United States)
RAID option ROM version: 17.5.0.4136
Driver version: 17.7.0.1006
ISDI version: 17.7.0.1006
Ethan Hsiao
Alberto_R_Intel
Hello Ethan_Hsiao, Thank you very much for clarifying that information.
We will continue with our research on this topic, as soon as I get any information I will post all the details on this thread.
Alberto R.
Alberto_R_Intel
Hello Ethan_Hsiao, Another update on this matter.
We just wanted to confirm a few details about this scenario:
Is this a regression?
Did it start happening after you installed a new Intel® RST driver or Windows* update?
Was it working fine with any old Intel® RST driver? If yes, which one?
This issue, is it happening on both generic Intel® RST driver and the version provided by the manufacturer of Intel® RST driver?
Did you make any changes to your system recently, like any additional hardware or swaps.
Fix Windows 10 error Kernel Security Check Failure
These are a few things we can do to try to fix this error. First, let’s perform a Windows* update to make sure you’re running the latest version:
  • Navigate to "Settings", "Update & Security" and Windows Update.
  • Click "Check for updates".
  • Update everything as required.
Then:
  • Type or paste "verifier" into the Search Windows box.
  • Select "Create standard settings" and click Next.
  • Select "Automatically select unsigned drivers" and click Next.
  • Update any or all drivers on the list.
  • If you have just upgraded to Windows* 10, also try "Automatically select drivers built for older versions of Windows" and click Next
  • Update those too if they don’t overlap with step 4.
Then:
  • Open a CMD window as an administrator.
  • Type or paste "sfc /scannow" and press Enter.
  • Let the process complete and make any repairs as necessary.
In the vast majority of cases, one or all of these procedures fixes the Windows* 10 Kernel Security Check Failure.
If by any chance the issue persists after trying the steps above, please test the system in safe mode and let us know the results once you get the chance.
Alberto R.
Ethan_Hsiao
Hi Alberto,
=> Yes
=> No, it started happening after I enabled RST. If I configured it as the standard NVMe, it was fine.
=> No, never worked. I've tried old RST (UEFI/OptionROM version 16.x), the OS stuck on the Windows going round.
=> All of RST drivers have this issue!
=> I just added the "4TB" NVMe drive and configured it to RST controlled.
Did Intel try to use the "4096GB" NVMe drive on RST?
If yes, you can see what's happened.
Ethan Hsiao
Alberto_R_Intel
Ethan_Hsiao, Thank you very much for letting us know that information.
Before we can continue with our research, could you please provide the results of following the troubleshooting steps provided previously?
Alberto R.
Ethan_Hsiao
Hi Alberto,
If I change the NVMe Drive to 2TB and also configure it by RST controlld, Windows works fine.
So, I'm sure that is the compatibility issue with RST/4TB drive.
Ethan Hsiao
Alberto_R_Intel
Hi Ethan_Hsiao, Thank you very much for your response.
We will continue reviewing this case and as soon as I get any more updates I will post all the information on this thread.
Alberto R.
Ethan_Hsiao
Hi Alberto,
Is there any update?
Ethan Hsiao
Subin_P_Intel
Hi Ethan,
The case has been sent to RST engineering. Can you tell me what is the model of the 4TB drive?
Is there any crash log dump that you can share with us?
Ethan_Hsiao
The SSD is still under testing.
Due to the OS was installed on it, I can't get the log.
I'll try to get the memory dump or any log for you.
Thanks!
Ethan_Hsiao
I tried to enable memory dump and boot log.
But nothing I got after BSOD.
I recorded a video to let you know the symptom.
https://photos.app.goo.gl/jtfozBvaVvLDryYR7
Please refer to it, thanks!
Ethan Hsiao
Subin_P_Intel
Thanks for the video.
What is the model of the 4TB NVME drive that you have added. Sorry if it has been answered before.
