Rapid Storage Technology
Intel® RST, RAID
2172 Discussions
RAID 5 Initialization extremely slow on Z790
Dj_Kuehn
I have 3 new 2 TB SATA hard drives in a fresh high end system build. Before creating the array, the 3 drives were benchmarked individually, each averaging apx 220mb/s read and 200 mb/s write (sequential, crystal diskmark). This was to verify the drives performed to spec.
However, when I created the RAID 5 array in the Optane software, initialization is EXTREMELY slow. I know this is a process that takes a while normally. However, after 16 hours it is only at 7%. At this rate I'm looking at nearly 10 days for initialization.
Questions:
  1. What is a "normal" time for this process?
  2. Assuming this is abnormal, what could be the cause?
  3. If this eventually finishes then someday a drive fails, does that also mean I'm looking at a similar time frame to rebuild the lost data? If so, I need to rethink RAID 5 as a viable option and get another drive for 0+1.
  4. While initializing, task manager shows zero drive activity. Is this normal?
  5. While initializing, disk benchmark numbers drop tremendously. Read/write goes from 220/200 down to like 40/20.  Normal?
System specs:
MSI Z790 MB
i7 13700K
32gb RAM
3x Seagate ST2000DM008 in RAID 5 (new, unused, blank)
Samsung 980 Pro 2tb system drive.
Windows 11, latest intel RST drivers (19.5).
BrusC_Intel
Hello, Dj_Kuehn.
Thank you for posting on the Intel community Support forum.
I will move your thread to the dedicated Intel Rapid Storage Technology section so it can be answered as soon as possible.
One of m y colleagues will contact you soon.
Bruce C.
IsaacQ_Intel
Hello @Dj_Kuehn
In order to furnish you with precise information in response to your queries, I will undertake additional research. As soon as I have obtained the requested information, I will promptly communicate it to you.
Isaac Q.
IsaacQ_Intel
Hello @Dj_Kuehn
We're currently conducting further research and will promptly provide you with the results.
Isaac Q.
Peppe75
I've the some problem on Asus z790 e gaming strix,  the raid 5 (
three disk nas WD 4 TB) performance on my previous z87 chipset was perfect!
tested driver  RST/VMD:
 19.5.5.1052 WHQL (intel download)
19.5.0.1037 (from manufacter)
IsaacQ_Intel
Hello @Dj_Kuehn
We greatly appreciate your patience and sincerely apologize for the delay in our response. Your inquiries have been diligently forwarded to our specialized RAID department, ensuring that we provide you with the most precise and comprehensive information. Below, you will find their responses:
  • What is a "normal" time for this process?
This depends on the disk performance. For example, different performance between GEN3/GEN4 NVMe, SATA SSD, SATA HDD 5400 rpm and 7200 rpm
  • Assuming this is abnormal, what could be the cause?
We previously observed one performance issue related to SATA HDD cache design. Ex: Seagate ST500LX025
  • If this eventually finishes then someday a drive fails, does that also mean I'm looking at a similar time frame to rebuild the lost data? If so, I need to rethink RAID 5 as a viable option and get another drive for 0+1.
One disk failed, it can still work, and, you can get a new disk to rebuild RAID5. This rebuild can be done by HSA app.
  • While initializing, task manager shows zero drive activity. Is this normal?
RAID “initializing” is mainly working inside RST driver.
  • While initializing, disk benchmark numbers drop tremendously. Read/write goes from 220/200 down to like 40/20. Normal?
Since the RST driver is working the “initializing”, it’s expected the performance impact.
@Peppe75, we kindly recommend that you initiate a new discussion thread to address and resolve your concern more effectively.
Isaac Q.
IsaacQ_Intel
Hello Dj_Kuehn
We hope you are doing fine.
Let us know if you still need assistance, otherwise the thread will be closed.
Isaac Q.
Dj_Kuehn
Yes, but that "answer" didn't really answer anything.
That is, frankly, a total non-answer. How about this equivalent question and answer:
Customer: "Hi, my car will only go 5mph and smoke is pouring out the back. Is this normal?"
Company: "Thanks for contacting us. The top speed of a car depends on many factors. The horsepower, wheel size, transmission gearing, and aerodynamics all play a role."
Customer: "Um, thanks?"
I gave thorough system specs as well as the exact make and model of drive. The process did eventually complete after a whopping 10 days. I still have no idea if a rebuild will also take 10 days. The benchmark numbers after completing this are roughly equivalent to 2 drives in RAID 0 for read performance, but about that of a single drive in write performance.
The only conclusion I can draw here is that RAID 5 is broken on the Z790. You're far better off with 2 drives in RAID 1 or 4 drives in 0+1.
IsaacQ_Intel
Hello @Dj_Kuehn,
We sincerely apologize for the inconvenience caused by our previous response. Unfortunately, providing a specific timeframe is challenging due to the multitude of factors involved, as previously mentioned.
The time required to create a RAID setup is influenced by a wide array of variables, including the number and capacity of drives, the type of RAID controller or software being used, drive speeds, RAID level and configuration, background processes, RAID controller cache, file system format, and more.
Even when estimating in an ideal scenario where both read and write processes occur simultaneously and efficiently, the total time for RAID 5 creation is approximately 39,098.18 seconds, roughly equivalent to 10.86 hours. However, please note that this is a rough estimate, and the actual duration can fluctuate due to factors such as the efficiency of your RAID controller, system workload, and potential bottlenecks.
Additionally, the RAID creation process may involve supplementary setup and verification steps that could extend the overall timeframe.
Isaac Q.
Dj_Kuehn
I completely understand and agree with everything you just said.
However, there is a significant difference between 10.86 hours and 10 DAYS. No degree of variation in those variables justifies that, particularly considering most of the items listed are not variables at all. Here we know the controller, drive speeds, raid level, cache, etc. That only leaves background processes and file system format.
Background processes shouldn't really matter since you already said the process is almost entirely handled by the controller. Regardless, the computer was effectively idle for the vast majority of those 10 days. Furthermore, the drives were (and still are) completely empty with zero utilization. As for file system, all were default (NTFS) settings in windows 11. It's also worth reiterating that this is a brand new high end system using Intel's supposedly top of the line PC chipset.
I'm going to stop following this thread now. I did not expect there to be any immediate solution, but I also did not expect a flat out denial that there was even anything abnormal about the situation.
IsaacQ_Intel
Hello @Dj_Kuehn,
I apologize for any frustration or confusion caused. Since you've expressed your decision to discontinue the discussion on this topic, I will respect your request and close the thread. If you ever have further questions or need assistance in the future, please don't hesitate to reach out. Have a great day!
Isaac Q.
homeexpert12
Another potential reason for slow RAID 5 initialization is if the system is performing background tasks or disk checks during the initialization. This could impact the speed. MOFA Attestation is crucial for ensuring the integrity of data, especially in RAID setups.
homeexpert123
It's perplexing to witness RAID 5 initialization dragging at a snail's pace on Z790. It's akin to dealing with a persistent pest control issue, requiring meticulous attention to ensure optimal performance in both scenarios.
Tuyen
It's not just Z790.  I'm having the exact same issue on Z690 with a RAID 5 array that I just created.
i9-12900K CPU.  MSI Z690 ACE motherboard.  No background processes that are slowing anything down.  CPU utilization is fluctuating between zero and one percent.
I went to bed when the process started.  Woke up, did my usual routine, and then checked on its status around 12 hours after it started.  So far I'm at 11%.  So if you do the math, I'll be here waiting for this thing to "initialize" for the next FIVE DAYS.
Keep in mind, this is something I would consider to be a small array.  It consists of four 4 TB drives.  I would be completely horrified if I was using 20 TB drives.
Clearly there's a serious problem with Intel's drivers, its software, its implementation, or any combination thereof.
Furthermore, why does an "initialization" take the exact same time as a complete rebuild?  If you're creating a brand new array, wouldn't it make sense that a simple format would suffice?  What the hell is it doing during this "initialization" phase?  The drives are completely EMPTY.
A little while ago, when I swapped one of the drives in my Synology NAS, it took about 28 hours to do a complete rebuild (also RAID 5).  That NAS has four drives, each of which is 16 TB.  The NAS has a much weaker processor, much less RAM, etc., and yet it still finished a 64 TB rebuild in just a little more than a full day.
Mike37
Can anyone recommend a decent RAID card as an alternative?  I'm having the same problem with a Z790A with i9-14900.  I was really liking the setup till I got the this RAID5 setup part.
alyxjame
RAID 5 initialization on the Z790 feels painfully slow, much like tackling a stubborn pest control problem. Both demand careful attention to detail to achieve smooth, reliable performance.
