Rapid Storage Technology
Intel® RST, RAID
RST Error Messages
BHall6
Is there a guide to RST error messages?
For instance, I'm seeing this error at boot on a Dell Precision with a two drive RAID, on the second drive:
Error Occurred(0,1)
I haven't found any reference to that error anywhere. Yes, the drive may be failing, but what does the error message actually mean?
Hello BRH,
Please bear in mind that your best support is Dell as they are more familiar with the total configuration of your integrated system and the way all the features interact with each other.
Intel sells products to various OEM's (Original Equipment Manufacturers), who then integrate them, with other system components (power supplies, disk drives, add in cards, software, etc).These software may be customized to the OEM's specifications.
This error basically is referring that a HDD has failed or it has been disconnect, you can check more error detail when your run the IRST report.
Ivan.
