just a confirmation please: does the RST W10 driver exist for the HM55 express chispset ?
(I guess no).
Currently I'm running the MS ' one on a brand new SSD and I'd like to get better performances.
Hello DPetr7,
I understand that you would like to know if there are Intel® Rapid Storage Technology (Intel® RST) drivers for Windows® 10 compatible with the Mobile Intel® HM55 Express Chipset.
The latest Intel® RST driver supporting the Mobile Intel® HM55 Express Chipset is driver version 12.9.0.1001, however, this driver and previous versions do not include support for Windows® 10, the driver is available for Windows® 8.1/8/7 and Windows® Server 2012/2008R2/2008.
The first Intel® RST driver for Windows® 10 is driver version 14.8.16.1063, and this driver and newer versions do not support the Mobile Intel® HM55 Express Chipset nor the Intel® 5 Series Chipsets.
This information is available on the "Read Me (txt)" and "Release Notes" of the driver download page.
Andrew G.
A Contingent Worker at Intel
Hello DPetr7,
The information on the previous post is correct regarding Intel's generic drivers for Intel® RST.
However, we would like to recommend you to check with the Original Equipment Manufacturer (OEM) of the device (laptop, tablet, desktop PC) regarding supported drivers for your system.
They can confirm if your system is compatible with Windows® 10 and the supported drivers available for each Windows® version. System manufacturers regularly customize Intel generic drivers to meet the needs of their specific system design. In such cases, the use of the Intel generic driver update is not recommended.
Andrew G.
Using a version of RST that is not intended for your OS is a bad idea.
Doc
Let's start here: Are you using RAID or do you actually NEED RST?
If no, then avoid the entire issue.
Doc
There has been some debate, long ago, about which is the better performer: ahci or RST. If you are not using raid, stay with the MS AHCI. You will be glad you did, and any performance difference (if any) is negligible.
Doc
