I have a raid 1 on an MSI X58 Platinum SLI motherboard - Intel RST on ICH10R - Win7 64 Pro
This ran almost flawlessly for 3 years with seagate 320gb drives,until a drive failed.
I upgraded to SSD - Intel 520 SSD 240gb - in December.
SSD Raid1 is unstable and has been since created. Currently using latest Intel RST drivers and software as of 1/26/2013 - v 11.7.0.1013
I've done all the troubleshooting I can, change ports, sata cables, power, drivers reinstall, different drivers version, and so on.
The drive failure follows the drive, but with so many different errors occurring I am not yet sure the drive is faulty. Errors which point to a specific drive always point to the same drive, sn CV231002JA240CGN
The raid works, but intermittently (daily or 3 times a day) rebuilds the array. Sometimes a "smart event" occurs. Sometimes a disk is left in "failed" state.
SSDToolbox shows no "smart events".
The failing disk is always the same disk unit.
Although I suspect some problem with this disk, I also get errors in the software/driver:
Here are the types of events I see:
93118 Application Information 1/26/2013 22:11:10 PM IAStorDataMgrSvc 0 7001 i7 0 156 SATA array disk: Removed.
93119 Application Information 1/26/2013 22:11:10 PM IAStorDataMgrSvc 0 7000 i7 0 208 Unknown SSD on Controller 0, Port Unknown: Detected. 93120 Application Information 1/26/2013 22:11:12 PM IAStorDataMgrSvc 0 7000 i7 0 192 SATA SSD on Controller 0, Port 1: Detected.
This event, once it begins, repeats endlessly until the RST service is restarted:
93108 Application Information 1/26/2013 19:11:58 PM PSI 0 0 i7 0 3296 PSI.DataLockException: Cannot get changes, data is not protected with a lock.
at PSI.PsiSystemDataModel.GetChanges(PsiSystemDataModel instance)
at PSIClient.PsiClient.GetChanges() at IAStorUtil.SystemDataModelListener.SystemDataModelChanged(Object sender, PropertyChangedEventArgs e)
at PSIClient.PsiClient.OnPropertyChanged(String value)
at PSIClient.PsiClient.PsiSystemDataChanged(Object sender, PsiSystemDataChangedEventArgs e) at PSI.PsiSystemDataModel.InvokeChangeEvent(Object source, Int32 updateNumber, String updateReason, DateTime updateTime)
at PSI.PsiSystemDataModel.EndUpdate(Int32 updateId)
at PSI.PsiSystemDataModel.RecordExceptonInDataSet(Int32 errorCode, Int32 errorUpdateId, String errorText, String errorMessage, Boolean isBusyError, UpdateReasonDomain actionIfAny, Exception exception) Stack Trace
This event always occurs with every start of the GUI after a few minutes:
93085 Application Information 1/26/2013 19:11:11 PM IRST_UI 0 0 i7 0 3760 Unable to perform actionStack Trace:
at System.Environment.GetStackTrace(Exception e, Boolean needFileInfo)
at System.Environment.get_StackTrace()
at PSI.PsiSystemDataModel.InvokeAction(PsiAction action)
at PSI.PsiAction.PsiAction_DoWork(Object sender, DoWorkEventArgs e)
at System.ComponentModel.BackgroundWorker.OnDoWork(DoWorkEventArgs e)
at System.ComponentModel.BackgroundWorker.WorkerThreadStart(Object argument)
at System.Runtime.Remoting.Messaging.StackBuilderSink._PrivateProcessMessage(IntPtr md, Object[] args, Object server, Int32 methodPtr, Boolean fExecuteInContext, Object[]& outArgs) at System.Runtime.Remoting.Messaging.StackBuilderSink.AsyncProcessMessage(IMessage msg, IMessageSink replySink)
at System.Runtime.Remoting.Proxies.AgileAsyncWorkerItem.DoAsyncCall()
at System.Runtime.Remoting.Proxies.AgileAsyncWorkerItem.ThreadPoolCallBack(Object o)
at System.Threading.QueueUserWorkItemCallback.WaitCallback_Context(Object state)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean ignoreSyncCtx) at System.Threading.QueueUserWorkItemCallback.System.Threading.IThreadPoolWorkItem.ExecuteWorkItem()
at System.Threading.ThreadPoolWorkQueue.Dispatch()
at System.Threading._ThreadPoolWaitCallback.PerformWaitCallback()System.Data.ConstraintException: Failed to enable constraints. One or more rows contain values violating non-null, unique, or foreign-key constraints.
at System.Data.DataSet.EnableConstraints()
at System.Data.DataSet.set_EnforceConstraints(Boolean value) at PSI.PsiSystemDataModel.UpdateDriverData(Int32 updateId) at PSI.PsiSystemDataModel.DriverAction(Int32 updateId, Dictionary`2 actionRequest)
Also seen repeating:
92415 Application Information 1/26/2013 15:19:50 PM IRST_UI 0 0 i7 0 1204 Exception in pollWorking_DoWork()Failed to enable constraints. One or more rows contain values violating non-null, unique, or foreign-key constraints.System.Data.ConstraintException: Failed to enable constraints. One or more rows contain values violating non-null, unique, or foreign-key constraints.
at PSI.PsiSystemDataModel.pollWorker_DoWork(Object sender, DoWorkEventArgs e)
A recurring smart error event:
1791369 System Error 1/26/2013 9:17:35 AM iaStorA 0 4102 i7 40 164 Error log: Smart event occured on disk :CV231002JA240CGN
Another type of GUI error:
90763 Application Information 1/25/2013 14:03:21 PM IRST_UI 0 0 i7 0 216 Error: Action failure, Action request timed out DiskMarkAsNormal
