Rapid Storage Technology
Intel® RST, RAID
1930 Discussions
Raid0 ⇒ Raid1への変更について
kat
購入時にIntel Optane Memory and Storage ManagementでRaid 1が組まれていましたが、
Raid 0へ変更を行いました。
Raid 0へ変更後にRaid 1に戻したいと思いましたが、
Raidタイプの変更が出来ません。
Raid 1に戻すにはどのようにしたらいいのでしょうか。
Sebastian_M_Intel
Hello kat,
Thank you for posting on the Intel® communities.
Our support is only provided in English. We may not be able to translate screenshots attached to the thread. To better assist you, we use an internal translation tool, so the translation might not be accurrate.
So we can have more information about your system, please provide the following:
1. Run the Intel® System Support Utility (Intel® SSU) and attach the report generated:
  • Open the application, check the "Everything" box, and click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
  • Click on the menu where it says "Summary" to change to "Detailed View".
  • To save your scan, click on "Next", then "Save".
  • Use the option under the reply window to attach the report to the thread (Drag and drop here or browse files to attach).
2. Provide the System Report for Intel® Rapid Storage Technology
Sebastian M
Intel Customer Support Technician
kat
Thank you for your reply.
I'm sorry I asked you in Japanese.
It's SSU report.
Please Verification.
Sebastian_M_Intel
Hello kat,
Thank you for the information.
The transition from RAID 0 to RAID 1 is not supported: https://www.intel.com/content/www/us/en/support/articles/000005997/technologies.html
In this case, you will need to set all the drives to non-RAID status, and recreate the RAID array from scratch from the system BIOS. The correct instructions for this need to be consulted with the the manufacturer (OEM) of your PC.
Sebastian M
IntelSupport
Community Manager
Hello kat,
Were you able to check the previous post and check our recommendations? Please let me know if you need more assistance.
Sebastian M
Sebastian_M_Intel
Hello kat,
We have not heard back from you, so we will close this inquiry. If you need further assistance or if you have additional questions, please create a new thread and we will gladly assist you.
Sebastian M
