Rapid Storage Technology
Intel® RST, RAID
2197 Discussions
Rapid Start vs Rapid Response vs Rapid Storage
DEdwa3
Could someone explain how these all work together? I have a DH87RL board with one HDD and an mSATA SDD. I was trying to get Rapid Start to work to no avail. My system is using EFI with Windows 8.1 x64. The instructions I linked below were no help in configuring it. The partition would change to unknown when I use the 'set id' command. The vBIOS is set to use RAID and Rapid Storage Technology is working. Maybe I have rapid start configured and don't even know it.
My Rapid Storage Setup is in the image below. I clicked some buttons trying to turn on acceleration as I read that was needed. This is the result. Top array is my mSATA SSD.
I followed the instructions here:
http://download.intel.com/support/motherboards/desktop/sb/rapid_start_technology_user_guide_for_uefi1.pdf http://download.intel.com/support/motherboards/desktop/sb/rapid_start_technology_user_guide_for_uefi1.pdf
When I try to install Rapid Start I get:
I'm just a bit confused about all this. What did I just do? Why won't Rapid Start install? It is enabled in the bios and hibernation is set to immediate. Any help would be greatly appreciated.
Kevin_M_Intel
Hi arkiados,
Here is very important to mention that Rapid Start is a feature that allows your computer to go from being in a very deep-sleep to fully awake in a flash. On the other hand, Intel® Smart Response allows accelerating the system mechanical disk using a SSD and it is part of the Rapid Storage technology Software. ; However, you can use only one technology at the time either Rapid Start or Intel® Smart Response
You can get the Rapid Start guide at the following link:
http://www.intel.com/support/motherboards/desktop/sb/CS-033637.htm?wapkw=(rapid+start) http://www.intel.com/support/motherboards/desktop/sb/CS-033637.htm?wapkw=(rapid+start)
Also, you can access the following link to check the Intel® Smart Response Technology:
http://www.intel.com/support/chipsets/sb/CS-032826.htm?wapkw=(smart+response) http://www.intel.com/support/chipsets/sb/CS-032826.htm?wapkw=(smart+response)
This may be the reason why you are having problems using both technologies at the same time.
Kevin_M_Intel
Hi arkiados,
DEdwa3
All of my other posts on these similar issues:
DH87RL Rapid Storage Accelerated Volume Selection
/thread/47072 https://communities.intel.com/thread/47072
Rapid Start vs Rapid Storage vs Rapid Response, etc.
/thread/47005 https://communities.intel.com/thread/47005
/thread/46996 https://communities.intel.com/thread/46996
DH87RL Will Not Boot
/thread/47022 https://communities.intel.com/thread/47022
DEdwa3
Thanks. I think I will avoid using Rapid Start if I can get my system to boot again. I was not aware only one could be used at a time.
RBail1
According to the Rapid Start guide you've linked to, you can install both Rapid Start and Smart Response on the same system, as long as you install Smart Response BEFORE setting up Rapid Start.
Is the guide in error?
Kevin_M_Intel
Hi rbailin,
In fact the guide says that you can install the Smart response before setting up the Rapid Start but the system cannot use both at the same time. This is something that is not pointed in the user guide and I will send to be added it to the file.
Thanks for the feedback.
