Rapid Storage Technology
Intel® RST, RAID
2189 Discussions
Rapid Storage Technology - User Interface after install
frontloop
I have installed the RST setup on my PC (Asrock Z690, Windows 10 Pro) after creating a RAID10 Volume in the Bios. The drive works fine, WIN recogniced the drive and I could create a partition in Windows, but I can not find the RST user interface. There is no icon in the tray and nothing to be found under "apps".
I installed the latest package from the Intel download center.
How can I administer the RAID without the UI?
THX
Josef
Alberto_R_Intel
frontloop, Thank you for posting in the Intel® Communities Support.
In reference to this scenario, in the following link you will find the UI for Intel® RST which is a generic version:
https://apps.microsoft.com/store/detail/intel%C2%AE-optane%E2%84%A2-memory-and-storage-management/9MZNG5HZWZ1T?hl=en-us&gl=us
Keep in mind that, in this case, you will be able for example to monitor and create a RAID with the UI, but, since you created your current RAID volume through the BIOS, in order to modify it you will need to do the same and access the BIOS to be able to apply the changes.
We always recommend to use the RST version tested and validated by the motherboard's manufacturer since it contains the customizations done by them, version 19.1.0.1001.4:
https://download.asrock.com/Drivers/Intel/SATA/RapidStorage(v19.1.0.1001.4).zip
https://www.intel.com/content/www/us/en/support/articles/000005639/technologies/intel-rapid-storage-technology-intel-rst.html
Albert R.
