Rapid Storage Technology
Intel® RST, RAID
2209 Discussions
Re: Intel© Accelerated Storage Manager - problem verification
oGaut
Hi, i got the same the same problem i attach the SSU report.
Can't find where i download this version.
Thank you
Hello got_fr,
Thank you for bringing this to the Intel® Community. I am sorry to hear you are having issues with this matter.
I branched your post in order to isolate your question and then better assist you.
Please provide the following information:
  • Could you please confirm the issue you are facing?
  • Is there any particular reason why you want to use the Intel Accelerated Storage Manager?
Amy C.
oGaut
Yes i Still face the problem.
Infact i need ASM to use an ssd as cache for raid 5 volume.
I post here for this :
/thread/121481 got_fr, can you please let me know if you have any particular reason to use the Intel Accelerated Storage Manager. Please also provide a screenshot of the login you are getting.
Regarding your other thread, an agent should be working with you soon.
Amy C.
oGaut
The particular reason is that i want to activate ssd caching and i thought that ASM was a way to do it.
Here is the screenshot :
Thank you for the screenshot.
Please let me double check this.
Amy C.
oGaut
Hi
But intel rst refuse to install on my system (windows 2016 64) i can juste instzll rste wich doesn t have this option.
Thank you
Anonymous
Not applicable
We would like to inform you that Intel® RSTe doesn't have a feature to setup an SSD as cache device.
In your case our best recommendation will be to take advantage of the Intel® Cache Acceleration Software which is a software that Intel has developed in order to use SSD's as cache devices. You can check more information about the software https://www.intel.com/content/www/us/en/software/intel-cache-acceleration-software-performance.html here
Hope this helps. Please let us know.
