Rapid Storage Technology
Intel® RST, RAID
SATA available disk: Removed.
Shreyas_B
初学者
8,044 次查看
I'm getting this error from past a month ,To remove this error i've reset the pc but also it didn't solve the error.
now its been a while, i cant even share files to other devices it pop ups the message SATA available disk removed and Data(D) is removed from my pc. How can i resolve it.
 I've got MSI GL63 8RD
0 项奖励
1 解答
n_scott_pearson
超级用户
7,992 次查看
No, keep it in AHCI Mode. Do not use the RAID or Optane modes unless you have, well, a RAID array or Optane module present.
That error is telling me that you have a drive that is predicting it failure (via S.M.A.R.T.). In combination with the drive dropping out of the ready state, I would say that this is a legitimately failing drive. I would replace this drive as soon as possible.
在原帖中查看解决方案
0 项奖励
8 回复数
n_scott_pearson
超级用户
8,028 次查看
Is your laptop using RAID? Is your laptop using Optane? If the answer to both of these questions is No, then you do not need and should uninstall Intel RST, You should also go into BIOS Setup and change the setting of the SATA Mode parameter (back) to its AHCI setting.
0 项奖励
LeonWaksman
超级用户
8,022 次查看
Just when you will change the SATA mode to AHCI, set your Windows to SAFE boot mode first (otherwise your system become not bootable).
Leon
0 项奖励
Shreyas_B
初学者
8,012 次查看
Sir it is already in AHCI MODE. should i change that to Intel RST Premium With Intel Optane System Acceleration(Mode select.jpeg) ? and sir i'm also getting this error message(Snip.png) dialy.
0 项奖励
n_scott_pearson
超级用户
7,993 次查看
0 项奖励
Shreyas_B
初学者
7,889 次查看
Thanks for the solution.
i'm thinking of buying a wd ssd to replace my hdd.
0 项奖励
utkarshethical27
初学者
7,033 次查看
Hi there,
my drive is healthy and removing when i was starting bluestack, if i did not start bluestack disk did not get removed. i have purchased my disk 1 year 6 months before of wd 500gb.
Please Help Me!
0 项奖励
Johnbelley
新手
8,006 次查看
If you have a DVD drive in your system you can try swapping the cables to see if that helps. I would back up all the important stuff on that drive in case it's dying.
0 项奖励
Shreyas_B
初学者
8,000 次查看
no i dont have dvd drive ,but i have backup everything.
0 项奖励
回复
