Rapid Storage Technology
Intel® RST, RAID
2213 Discussions
Storage technology Intel® Rapid
Bobik
I have an HP Pavilion - 15-au112ur, it has the Intel® Rapid Storage Technology program, it shows an empty internal port, I wanted to know this empty hard drive port? how to find out what type --- sata? or m2? when opening the laptop, I did not find a free port for connecting a disk! Can you please tell me what exactly the Storage technology Intel® Rapid program shows?
n_scott_pearson
Al is correct; you need to contact HP to get more information on the ports that are populated in your system. RST can show the available  ports that the hardware (chipset) supports; whether these ports are actually available/useable depends upon the system's design - and this is something that only HP can answer for their designs.
What Al meant was that, unless you are making use of Intel's RAID or Optane technologies, you do not need the RST package installed and I (and Al, obviously) recommend that you uninstall it. IMHO, HP (and Dell) are doing their customers a disservice installing this package by default. It introduces so many unnecessary complications and sets up customers to potentially lose the contents of their secondary drive with one errant keypress. If you don't absolutely need it, don't install it.
Hope this helps,
Bobik
AlHill
One post is enough.  Stay with your original post.
Bobik
Can you help me with my question?
AlHill
No, and I would be contacting HP regarding their hardware regarding this empty internal port.  Furthermore, do you really need raid?  If not, do away with it.
Bobik
Read the question more carefully, I did not ask about the raid! What internal empty port shows Intel Rapid Technology?
AlHill
And, read my answer more carefully.  I said you should ask HP about their hardware and that port.
n_scott_pearson
Hope this helps,
Bobik
Thank you for a very articulate answer.
