Rapid Storage Technology
Intel® RST, RAID
1898 Discussions
Windows 10 se queda bloqueado por problemas de acceso a disco
JRigo1
Hola,
De forma indeterminada al cabo de x minutos o segundos, a veces, el windows se queda colgado y en el monitor de recursos se ve perfectamente como el acceso a disco se queda a 0.
Saben qué sucede con el driver de RST? porque tengo la última actualización y a pesar de ello se sigue quedando colgado. Parece como si el disco de golpe se haya desconnectado.
Espero que me puedan ayudar.
Muchas gracias,
ttecles
Hi ttecles: Thank you very much for contacting the Intel® Rapid Storage Technology communities. We will do our best to assist you with this scenario.
In order to deliver the most accurate assistance, we just wanted to confirm some details about your system. Please provide the SSU report:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
Also, please provide the RAID report:
https://www.intel.com/content/www/us/en/support/articles/000006351/technologies.html https://www.intel.com/content/www/us/en/support/articles/000006351/technologies.html
To attach a file, you must click "Use Advanced Editor" in the top right corner of the response box, then the "attach" option will appear in the bottom right corner of the response box
Any further questions, please let me know.
Alberto R
JRigo1
I am sending you the files.
Hope it helps to fix it.
Thanks and regards,
Joan
Hi ttecles: Thank you very much for providing those files.
In order to try to fix this problem please try a BIOS update to version 3801:
https://www.asus.com/Motherboards/X99A/HelpDesk_Download/ https://www.asus.com/Motherboards/X99A/HelpDesk_Download/
Also, please use the option called "Verify and Repair" showing on Intel® RST.
Additionally, we also recommend to install the Intel® RST version provided by ASUS, version 14.5:
Alberto R
JRigo1
problem fixed!
Thank you very much Alberto.
Joan
ttecles: You are very welcome. Excellent, it is great to hear the problem was resolved.
Alberto R
JRigo1
Hi Alberto,
Problem is reproducing again. It seems Intel RAID configuration and Windows 10 does not like each other...
Any new suggestion?
Joan
Hi ttecles: We are sorry to hear the problem came back.
In this case we can try a Check Disk option:
https://technet.microsoft.com/en-us/library/ee872425.aspx
Or we can also try a System File Checker:
https://support.microsoft.com/en-us/help/929833/use-the-system-file-checker-tool-to-repair-missing-or-corrupted-system
Alberto R
JRigo1
Hi Alberto,
I ran a CHKDSK /f on the RAID volume and the sfc /scannow and I got no error.
And even after that, every time I try to install a Windows 7 as a virtual machine I cannot finish the installation due to the error. Disc shows 100% activity and no Read/Write operation is done on that Volume. The only thing I can do is to restart the computer...
Joan
ttecles: Thank you very much for providing those updates.
It seems to be the problem could be related to one of the hard drives or with the SATA controller on the board, at this point we recommend to get in contact with ASUS directly for further technical or warranty assistance:
https://www.asus.com/us/support/ https://www.asus.com/us/support/
Alberto R
