Just wanted to report that there may be something funky happening with the storage controllers, as my device manager is reporting "SATA AHCI" even though BIOS RAID has been configured.
Similar happened in 1511, however, back then it actually caused the drives to be unreadable.
The RAID array is currently OK, but normally should not be.
I'll take clips later and post
NeoBeum: Thank you very much for joining the Intel® communities.
Perfect, thank you also for sharing those details, take your time and once you get the chance please let us know the result.
Alberto R.
@ Intel Corporation
is there a chance that the iaStorA and iaAHCIC inf are incorrectly merged or deleted during the servicing stack update for Windows?
also, here's a snip
This is a SysInfo dump from April (I don't have a screen shot)
[SCSI]
Item Value
Name Intel Chipset SATA RAID Controller
Manufacturer Intel Corporation
Status OK
PNP Device ID PCI\VEN_8086&DEV_282A&SUBSYS_171D1043&REV_05\3&11583659&0&FA
I/O Port 0x0000F070-0x0000F077
I/O Port 0x0000F060-0x0000F063
I/O Port 0x0000F050-0x0000F057
I/O Port 0x0000F040-0x0000F043
I/O Port 0x0000F020-0x0000F03F
Memory Address 0xED416000-0xED4167FF
IRQ Channel IRQ 4294967285
Driver c:\windows\system32\drivers\iastora.sys (14.8.9.1053, 1.40 MB (1,469,952 bytes), 04/04/2018 22:36)
Name Microsoft iSCSI Initiator
Manufacturer Microsoft
Status OK
PNP Device ID ROOT\ISCSIPRT\0000
Driver c:\windows\system32\drivers\msiscsi.sys (10.0.16299.334, 273.40 KB (279,960 bytes), 25/03/2018 21:08)
Name Microsoft Storage Spaces Controller
Status OK
PNP Device ID ROOT\SPACEPORT\0000
Driver c:\windows\system32\drivers\spaceport.sys (10.0.16299.251, 557.90 KB (571,288 bytes), 11/03/2018 20:51)
Name Samsung NVMe Controller
Manufacturer Samsung Electronics Co., Ltd
Status OK
PNP Device ID PCI\VEN_144D&DEV_A802&SUBSYS_A801144D&REV_01\4&17C5C7ED&0&00E4
Memory Address 0xED110000-0xED113FFF
I/O Port 0x0000C000-0x0000C0FF
IRQ Channel IRQ 4294967294
IRQ Channel IRQ 4294967293
IRQ Channel IRQ 4294967292
IRQ Channel IRQ 4294967291
IRQ Channel IRQ 4294967290
IRQ Channel IRQ 4294967289
IRQ Channel IRQ 4294967288
IRQ Channel IRQ 4294967287
IRQ Channel IRQ 4294967286
Driver c:\windows\system32\drivers\secnvme.sys (2.3.0.1709, 129.48 KB (132,584 bytes), 13/10/2017 17:56)
[IDE]
Item Value
and here's the awesome sauce October Update SysInfo
[SCSI]
Item Value
Status OK
Driver c:\windows\system32\drivers\spaceport.sys (10.0.17763.1, 637.80 KB (653,112 bytes), 15/09/2018 17:58)
Status OK
Driver c:\windows\system32\drivers\secnvme.sys (3.0.0.1802, 130.98 KB (134,120 bytes), 18/05/2018 23:38)
[IDE]
Item Value
Name Intel(R) 8 Series Chipset Family SATA AHCI Controller
Status OK
PNP Device ID PCI\VEN_8086&DEV_8C03&SUBSYS_171D1043&REV_05\3&11583659&0&FA
Driver c:\windows\system32\drivers\iastora.sys (14.8.16.1063, 1.40 MB (1,469,952 bytes), 10/06/2018 12:25)
NeoBeum: Thank you for sharing those pictures.
In regard to your question, yes, that could be a possibility and in that case what we recommend first of all is to back up any important data you might have on the PC of and then to un-install the Intel® RST application from control panel and re-install it again.
You can always try to install Intel® RST version 14.8.16.1063:
https://downloadcenter.intel.com/download/26759/Intel-Rapid-Storage-Technology-Intel-RST-User-Interf...
Alberto R.
NeoBeum: I just wanted to check if the information posted previously was useful for you and if you need further assistance on this matter?
Alberto R.
Hi
I will be building a new system image for 1803 - there is something not quite right with Windows' Component Cleanup because the drivers are being changed, removed and reordered or ignored.
I'm not sure if I can be bothered reporting this information to Microsoft as it's been an issue since launch.
NeoBeum: Thank you very much for providing that information.
Perfect, take your time, please let us know the results of trying the new system image.
And yes, you can always submit this inquiry to Microsoft support web site, they might be able to provide further insights on this subject:
https://support.microsoft.com/en-us
Alberto R.
intel_corp
Updating status for this issue:
Reinstalling 1809 will BSOD at the Sysprep phase **1809 ISO from Microsoft - not yet customised.
PNP_STOPCODE
2018-11-05 18:22:49, Error MOUPG CMoSetupOneSettingsHelperT::GetSettingsParameters(198): Result = 0x8000000A2018-11-05 18:23:09, Error CONX Windows::Compat::Appraiser::AppraiserSettings::GetSettingsInternal (297): Failed to Query OneSettings [0x80070002].[gle=0x80070002]2018-11-05 18:23:13, Error CSI00000001 (F) STATUS_OBJECT_NAME_NOT_FOUND # 38# from Windows::Rtl::SystemImplementation::DirectRegistryProvider::SysQueryValueKey(flags = 0, key = 844 ('\REGISTRY\MACHINE\SYSTEM\Setup'), vn = [l:7 ml:8]'Compact', kvic = 2, kvi = 2, disp = 0)[gle=0xd0000034]2018-11-05 18:23:13, Error CSI00000002 (F) STATUS_OBJECT_NAME_NOT_FOUND # 37# from Windows::Rtl::SystemImplementation::CKey::QueryValue(flags = 0, kn = [l:31]'\Registry\Machine\SYSTEM\Setup\', vn = [l:7 ml:8]'Compact', ic = KeyValuePartialInformation, info = {l:0 b:}, disp = 0)[gle=0xd0000034]2018-11-05 18:23:14, Error CSI00000003 (F) STATUS_OBJECT_NAME_NOT_FOUND # 70# from Windows::Rtl::SystemImplementation::DirectRegistryProvider::SysQueryValueKey(flags = 0, key = 85c ('\REGISTRY\MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Fonts'), vn = [l:21 ml:22]'Arial Nova (TrueType)', kvic = 2, kvi = 2, disp = 0)[gle=0xd0000034]2018-11-05 18:23:14, Error CSI00000004 (F) STATUS_OBJECT_NAME_NOT_FOUND # 69# from Windows::Rtl::SystemImplementation::CKey::QueryValue(flags = 0, kn = [l:69]'\Registry\Machine\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Fonts\', vn = [l:21 ml:22]'Arial Nova (TrueType)', ic = KeyValuePartialInformation, info = {l:0 b:}, disp = 0)[gle=0xd0000034]2018-11-05 18:24:25, Error CONX 0xd0000034 Failed to add user mode driver [%SystemRoot%\system32\DRIVERS\UMDF\uicciso.dll]2018-11-05 18:28:52, Error CSI00000001 (F) 80220008 [Error,Facility=FACILITY_STATE_MANAGEMENT,Code=8] # 135314# from CWcmScalarInstanceCore::GetCurrentValue(options = 393216, status = '(null)', value = { type: 40972, bytes ( 12 ): 65006e002d00470042000000 })[gle=0x80004005]
2018-11-05 18:29:13, Error CSI00000002 (F) 80220008 [Error,Facility=FACILITY_STATE_MANAGEMENT,Code=8] # 229666# from CWcmScalarInstanceCore::GetCurrentValue(options = 393216, status = '(null)', value = { type: 40972, bytes ( 12 ): 65006e002d00470042000000 })[gle=0x80004005]
2018-11-05 18:29:28, Error [0x080831] MIGCSIAgent: Invalid xml format: FormatException: Component with display name: Plugin/{C939EC0F-2F56-4CE8-AF56-2336596A5FA7} already loaded __cdecl Mig::CMXEMigrationXml::CMXEMigrationXml(class Mig::CPlatform *,class UnBCL::String *,class UnBCL::XmlDocument *,class UnBCL::String *,class UnBCL::String *)2018-11-05 18:31:56, Error CSetupAutomation::Resurrect: File not found: C:\$WINDOWS.~BT\Sources\Panther\automation.dat[gle=0x00000002]2018-11-05 18:31:56, Error SP CSetupPlatform::ResurrectAutomation: Failed to resurrect automation: 0x80070002[gle=0x00000002]2018-11-05 18:38:07, Error [0x080831] MIGCSIAgent: Invalid xml format: FormatException: Component with display name: Plugin/{C939EC0F-2F56-4CE8-AF56-2336596A5FA7} already loaded __cdecl Mig::CMXEMigrationXml::CMXEMigrationXml(class Mig::CPlatform *,class UnBCL::String *,class UnBCL::XmlDocument *,class UnBCL::String *,class UnBCL::String *)2018-11-05 18:42:29, Error [0x0808fe] MIGPlugin {0b23c863-4410-4153-8733-a60c9b1990fb}: TableTextServiceMig!RemoveObsoleteCHSHKLMRegkey - fail to open regkey (software\Microsoft\CTF\TIP\{E429B25A-E5D3-4D1F-9BE3-0C608477E3A1}\LanguageProfile\0x00000804) = 22018-11-05 18:42:29, Error [0x0808fe] MIGPlugin {0b23c863-4410-4153-8733-a60c9b1990fb}: TableTextServiceMig!ApplySuccess() remove HKLM Registries error2018-11-05 18:42:29, Error [0x0808fe] MIGPlugin {526D451C-721A-4b97-AD34-DCE5D8CD22C5}: [shmig] onecoreuap\shell\propsys\schemacachehelpers.cpp(604)\shmig.dll!00007FFC791DD47E: (caller: 00007FFC791D57C7) ReturnHr(1) tid(1ec8) 80070002 The system cannot find the file specified.Msg:[Migrated key for Path $OFFLINE_RW_003ADB7E$SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\PropertySystem\PropertySchema.Migrated for 32-bit hive not found ] 2018-11-05 18:42:29, Error [0x0808fe] MIGPlugin {526D451C-721A-4b97-AD34-DCE5D8CD22C5}: [shmig] shell\shmig\propsysschema.cpp(28)\shmig.dll!00007FFC791D57DF: (caller: 00007FFC791D52AA) LogHr(1) tid(1ec8) 80070002 The system cannot find the file specified.2018-11-05 18:42:29, Error [0x0808fe] MIGPlugin {ee036dc0-f9b7-4d2d-bb94-3dd3102c5804}: BRIDGEMIG: ParseRegistryIfBridgeExists: offline key (new) = '$OFFLINE_RW_003ADB7E$SYSTEM\Setup\Upgrade\Bridge'2018-11-05 18:42:29, Error [0x0808fe] MIGPlugin {ee036dc0-f9b7-4d2d-bb94-3dd3102c5804}: BRIDGEMIG: ParseRegistryIfBridgeExists: query bridge presence key failed 0x139f, bridge present = 02018-11-05 18:42:29, Error [0x08038d] MIGFailure while calling IPostApply->ApplySuccess for Plugin={ServerPath="Microsoft-Windows-DirectoryServices-ADAM-Client\adammigrate.dll", CLSID={43CCF250-2A74-48c6-9620-FC312EC475D6}, ThreadingModel=Apartment}. Error: 0x800700022018-11-05 18:42:29, Error SP Error READ, 0x00000002 while gathering/applying object: apply-success, Action,CMXEPlugin,C:\$WINDOWS.~BT\Sources\ReplacementManifests,Microsoft-Windows-DirectoryServices-ADAM-Client\adammig... Will return 2[gle=0x000000cb]2018-11-05 18:43:14, Error [0x0808fe] MIGPlugin {0b23c863-4410-4153-8733-a60c9b1990fb}: TableTextServiceMig!RemoveObsoleteCHSHKLMRegkey - fail to open regkey (software\Microsoft\CTF\TIP\{E429B25A-E5D3-4D1F-9BE3-0C608477E3A1}\LanguageProfile\0x00000804) = 22018-11-05 18:43:14, Error [0x0808fe] MIGPlugin {0b23c863-4410-4153-8733-a60c9b1990fb}: TableTextServiceMig!ApplySuccess...NeoBeum: Thank you very much for letting us know those results.
In this case the next thing to do will be to report this problem to Microsoft directly or to get in contact directly with the manufacturer of the computer so they can provide the proper Intel® RST version for your system and further suggestion son this matter.
Alberto R.
intel_corp
Now I remember why I stopped using Feedback Hub.... because of moronic crap like this:
They want to be able to flag issues better... they can't even get their categories and 'problem types' right for users to post in an appropriate category...
Hmmm... Windows fails to reinstall...
NeoBeum: Thank you for sharing that information.
We are sorry to hear the problem persists, at this point either Microsoft or the manufacturer of the laptop will be able to further assist you.
Alberto R.
intel_corp
I found that Windows had reconfigured the BIOS during the 1809 Feature Update from 1803.
Changing the SATA settings back to RAID changed the device drivers - however - I still have no idea - how the RAID array was still readable with the AHCI drivers.
There is something seriously wrong with Windows.
I had previously named the disks (and have been since 1511 - for all devices... even everything in HID) for this very reason.
In this current screenshot - the disks reverted back to the original names prior to update. The only thing that hasn't been rectified is the disk enumeration.
The 'View Hidden Devices' is enabled and the previous hardware configuration devices are visible.
The NVMe disk was originally the first disk - disk 0. However it is now the last disk. I thought this was fixed in 1703-1709-1803 - however this latest update seems to have gone backwards for many things.
NeoBeum: Thank you very much for letting us know those results and for sharing that information in this thread.
Some changes are expected after doing a Windows update, however, all the information and details in reference to that matter will be provided by Microsoft.
Alberto R.
The update shouldn't be changing hardware configuration though.
I'll see if Microsoft have any idea why the update is doing this
NeoBeum: That is correct. Yes, perfect, that is the best thing to do next.
Alberto R.
For more complete information about compiler optimizations, see our Optimization Notice.
