I would like to install the Rapid Storage Technology driver update that will allow the current Windows 10 update to install. However, I am not certain which of the three is correct for my system. Which is:
Dell Inspiron 5567, Intel i5, 7th generation, 64 bit (currently shows RST driver version 15.2.0.1020).
Device Manager -> Disk Drive lists SK hynix SC311 SATA 256GB (not Optane).
I checked the Rapid Storage Technology status and Optane is not listed there either.
A search in the PC files turns up two Optane listings: 1) Optane.dll; and, 2) OptaneEventLogMsg.dll.
Am I correct to use f6flpy-x64.zip?
I am aware of the need to change the iStora.sys file name, but any other helpful information relating to the driver installation would be much appreciated!
KAlba, Thank you for posting in the IntelĀ® Communities Support.
We recommend to install the IntelĀ® Rapid Storage Technology driver provided by the manufacturer of the computer since that driver was customized by them work with your specific platform.
I looked on Dell's web site and the IntelĀ® RST version validated by them is 15.2.0.1020, A00:
https://www.dell.com/support/home/bg/en/bgbsdt1/drivers/driversdetails?driverid=D2JVJ&oscode=WT64A&productcode=inspiron-15-5567-laptop
As an option, we can always try to install the IntelĀ® RST generic driver version 15.9.6.1044, but just to let you know, since it is generic this version might or might not work with your platform:
https://downloadcenter.intel.com/download/28656/Intel-Rapid-Storage-Technology-Intel-RST-User-Interface-and-Driver
Please visit the following link in order to gather further details about the iastora.sys error message:
Alberto R.
A Contingent Worker at Intel
Thank you very much! I tried many times to locate the Dell version but was unable to & since my warranty is out they would not even tell me (š£) which one I need. I will give your supplied Dell link a try (probably not until tonight, though, when I will have more time) & let you know how it goes.
KAlba, You are very welcome, thank you very much for letting us know those details.
Perfect, no problem at all, take your time and once you get the chance please let us know the results of installing the IntelĀ® RST version provided by Dell.
Alberto R.
KAlba, I just wanted to check if you were able to install the IntelĀ® RST version provided by Dell and if you need further assistance on this matter?
Alberto R.
Hi KAlba, No problem at all, thank you very much for sharing that information.
Yes, of course, the thread will remain available for you for as long as is needed.
Just to let you know, I will do a follow up on this case in a couple of days.
I hope everything is fine with your family, take your time and once you have the chance please let us know the results.
Alberto R.
KAlba, I just wanted to check if you were able to do the test with the IntelĀ® RST validated by Dell?
Alberto R.
KAlba, I just wanted to let you know that if the problem remains with the IntelĀ® Rapid Storage Technology driver version provided by Dell, then please install version: 15.9.8.1050, that is the version recommended for this scenario as it was described in the link provided previously:
https://downloadcenter.intel.com/download/28997/Intel-Rapid-Storage-Technology-Intel-RST-User-Interface-and-Driver
Alberto R.
Mister Alberto,
I apologize for the sizable delay in responding. I have just returned, for a short time, and will have a couple of days to try and get this issue figured out - and hopefully resolved!
I clicked on the link provided in your earlier reply (for version: 15.9.8.1050) and was directed to Driver 17.5.2.1024 (https://downloadcenter.intel.com/download/29007/Intel-Rapid-Storage-Technology-Intel-RST-User-Interface-and-Driver?v=t), which is fine. However, I am not certain which download on the left hand side I should use, or, should I use all three?
Please advise when time allows.
Thank you!
Mister Alberto,
I realized, after I sent the last message, that I was looking at the Intel link and not the Dell link in your first response. I was able to download from the Dell link and am awaiting the Windows 10 update attempt. Once it has run again I will update this thread to confirm either success or failure (hopefully success!).
UPDATE:
I was able to install the Windows 10 1903 update successfully, after having installed the Dell version of the RST driver.
One note though. I saw on another online post to be very careful and be certain that the iaStorA.sys file is not being used as one could end up with a blue screen/error on restart. I did some searching and could not find that it was being used on my particular computer so I proceeded with the name change to iaStorA.sys_OLD. The Windows 10 1903 update was then able to install properly. Just to be sure the iaStorA.sys was OK - in case it was needed upon restart - and just before the obligatory post-1903 install restart, I went back in and changed the name by removing "_OLD". I then allowed the restart to compete the 1903 install. So far, everything is working fine.
I thank you immensely for your assistance - and patience - while I was away and unable to respond!!! Kudos to you for your help!
KAlba, You are very welcome, no problem at all, thank you very much for letting us know those results.
Perfect, excellent, it is great to hear that after installing the IntelĀ® RST version provided by Dell you were able to install the Windows* 10 1903 update successfully and everything is working fine.
Regarding the iaStorA.sys file there are different suggestions about what to do with it, but as long as Windows* is running properly and there are no blue screens then it should be fine.
We are glad to hear the Windows* 10 update was properly installed.
Any other inquiry, do not hesitate to contact us again.
Alberto R.
